Problem with Steering Wheel
Old Oct 9, 2004 | 01:30 AM
Creaminz's Avatar
I have been driving my car with shaky steering wheel for quite a long time, and I thought it was just worn out break pad, so couple of days ago I went to dealer and changed break pad for FREE? I didn't know break pad were covered under warranty. But the problem was he said my car has warped rotor so they fixed it and told that should be fine from now on. On the way back home driving about 50 mph my steering wheel went crazy!! It won't stop from shaking. So I called my dealer again and he said it could be caused by aftermarket wheels or when they( Local Tire shop ) installed them they didn't do alignment. I'm gonna go to Tire Shop tomorrow see if that's the case. Is anyone having this kind of problem with your aftermarket wheels? TSX...99 problems...BITCH there's another 1 !!!!!
Old Oct 9, 2004 | 09:01 AM
o3jeff's Avatar
The alignment usually will cause it to pull to one side or the other, but have them check the balance, that is what usually cases a steering wheel to shake.
Old Oct 10, 2004 | 01:07 PM
Wtbs2k's Avatar
I just picked up mine last night. On my way back home on the free way, the steering wheels shakes a little.Anyone else has the same problem?
Old Oct 11, 2004 | 04:47 PM
Tech SX's Avatar
Its definitely a wheel balance issue.....take your wheels and get them rebalanced......and make sure they do a dynamic and static blance.......good luck
Old Oct 11, 2004 | 05:42 PM
JTso's Avatar
Are your aftermarket wheels hub centric? If not, do you have the correct hub rings?
Old Oct 11, 2004 | 06:29 PM
xizor's Avatar
Bye TSX, hello domestic?
listen to the man, you 99% likely need hub rings
Old Oct 11, 2004 | 06:50 PM
Wtbs2k's Avatar
Thanks!
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
PortlandRL
Sep 14, 2015 12:01 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
