Problem with Intake
Old Mar 30, 2007 | 08:16 AM
AtlTSX90's Avatar
Problem with Intake
ok so i went to a meet at the mall were i live and noticed my gas was dropping alot. So i looked at my engine bay and found that a smaller hose towards the top of the intake with the little box attached was disconnected from the main intake. The hose had a smaller iron tube inside of it and everytime i drive somewere after i fix it, i check it again when i stop and its disconnected again. I dont no why it keeps slipping off, but is there any way i can make it stop falling off?
here is a pic of where it is at...
Old Mar 30, 2007 | 08:55 AM
LoveMyTL-S's Avatar
Are the clamps on tight? If not I'd get some replacement screw type clamps that you can tighten down with a screwdriver.
Old Mar 30, 2007 | 12:00 PM
tsxnation's Avatar
get the screw type clamps and remove the factory ones
the factory ones lose their recoil pressure after being removed a few times
Old Mar 30, 2007 | 12:57 PM
joerockt's Avatar
Just dial 1911
Yea, its the clamps. What fixed it for me is that I just had those two clamps trade places and its been fine for almost 3 years now...
Old Mar 30, 2007 | 01:03 PM
AtlTSX90's Avatar
thanks for the advice guys, so i should just by a two screw claps? and put one the hose that connects to small black box and one for the hose that has metal pipe in it?
Old Mar 30, 2007 | 01:26 PM
curls's Avatar
Someone stole "My Garage"
What the Acura mechanic did for mine when I was having that problem, was he got a piece of automotive hose of the same diameter but about 1/2" longer, and replaced the existing hose (from the fatter piece to the engine side), essentially removing the need for that metal tube splice inside the two hoses, and eliminating the need for one of the clamps. He used the screw-type clamps.
It's been fine for over a year. I think the Injen design / OEM design is a BIT to short, and once the engine rocks a bit in its mounts (from revving, etc.), it pulls at the connections (stretching the hose and pulling on the clamps) and pops off in one or more places. A longer hose and better clamps should fix this, as it did for me.
Old Mar 30, 2007 | 01:46 PM
jerzpwr's Avatar
just out of curiosity.. what are the affects of driving around without that tube connected? What harm does it cause to the car?
Old Mar 30, 2007 | 01:57 PM
curls's Avatar
As far as I know, nothing. It depends if that tube is a breather IN to the engine, or OUT of the engine. If it's IN, then the effect is its not pulling in filtered air, but instead pulling in unfiltered air.
Old Mar 27, 2008 | 08:19 PM
GTSX-05's Avatar
ASM 3G TL Type-S
Had a day off from school today so I decided to undergo the Injen install, the hardest part was tearing it all apart, + the infamous bolt which is a real pain to get off. All and all it was a clean install, but I also noticed after driving it around that the hose would disconnect itself like the OP, I “corrected” this and I use it in quotations because I haven’t put it to the test yet, by installing metal screw clamps like the ones that came with the Injen, just thought this would be helpful for those who undergo the install and run into similar problems.
cycdaniel
Dec 17, 2019 10:58 AM
kmarqueling
Oct 3, 2015 01:14 AM
Kevin Sami
Sep 22, 2015 09:59 AM
Abe_Froman
Sep 16, 2015 01:27 PM
C2CuSn07 TL
Sep 11, 2015 06:54 PM
