Problem Bleeding the Brakes
Old Jun 2, 2008 | 10:16 AM
dom's Avatar
dom
Changed all 4 pads and rotors on the weekend and wanted to bleed the brakes as well.
I was using a hand pump bleeding kit. The first wheel (driver front) went fine. fluid pressure was great, no problems. The pass front didn't go so well. When I loosened the nipple there was no pressure. The pump was ready but the flow was painfully slow and eventually stopped. No idea what to do from here. Is there air in the line? Should I change the nipple?
Any advice would be appreciated.
I stopped there and did not complete the rears as I wasn't sure if I should continue. Brake feel seems fine BTW.
Old Jun 2, 2008 | 10:34 AM
moda_way's Avatar
Did you try the traditional method of bleeding? Could've been a failure in the pump and nothing to do with the caliper at all. Just a thought. Additionally, there is always some buildup behind the caliper piston. That could be blocking the fitting and the messy solution is to remove the caliper, flip it upside down and remove the nipple. Pump a couple of times to clear it, use an air nossel to blow blockage out of the nipple (off the caliper) from the outside of it (you don't want to blow any blockage from the part that screws into the caliper to the outside of the nipple).
Of course, this just means you'll need to start the bleed over to get air out of the passenger caliper, but just some more thoughts.
Old Jun 2, 2008 | 10:42 AM
dom's Avatar
dom
Ya, traditional bleeding was also suggested by a co-worker. More pressure apparently.
I'll try that first and then try removing the nipple if need be. Thanks for the suggestion moda.
Thankfully doesn't sound like anything went too wrong.
Old Jun 2, 2008 | 11:17 AM
moda_way's Avatar
Yeah, worse thing that can happen, assuming you are driving the TSX and it is braking fine, is that the nipple is clogged... easy fix there as well.
Old Jun 2, 2008 | 12:08 PM
slobeatz's Avatar
Littering and.....
You were adding more brake fluid to the reservior as you went, right? Just asking, cause I almost forgot to keep adding as I went along.
Old Jun 2, 2008 | 12:42 PM
LukeaTron's Avatar
The nipples can be had at the auto parts store for relatively cheap. If you put the reservoir cap on, not much fluid will leak when you take the nipple off (some will obviously). If the nipple is plugged, the easiest fix would be to just put a new one on.
I'm going to be doing this project this week. I hope it goes more smoothly.
Old Jun 2, 2008 | 12:48 PM
moda_way's Avatar
I've done it twice, no issues other than a little fluid bypassed the piston seal (Not the dust boot) so next break job means a caliper rebuild for me.
Old Jun 2, 2008 | 12:52 PM
LukeaTron's Avatar
How were you able to tell it's leaking? How many miles are you at?
Old Jun 2, 2008 | 12:58 PM
dom's Avatar
dom
Yup.
mada51589
Jan 9, 2025 04:40 PM
kmawani
Feb 8, 2023 05:09 AM
pstomps
Feb 20, 2017 03:29 AM
cacheflowe
Sep 14, 2015 10:35 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
