Power windows 05 TSX
Anyone one else have problems with the one touch down feature? It happened for the second time last week, where it just doesn't work. The window still goes up and down when you hold it but not the one touch feature. The window was all the way up and down when i was trying it. The problem went away after an hour or so. Thanks in advance.
I had the same problem in my car. I brought it to the dealer and they replaced the power window controller. It took about an hour. If you get this done at the dealer make sure your remotes work before you leave. Mine didn't work and I had to bring my car back in to have them reprogrammed.
Same thing happened to me once. Thing is, the window had frozen due to weather, and I think I kept hitting the switch up and down. When it thawed and freed the window, the 1-touch didn't work for about 20-30 minutes, and has worked fine since.
k6biv
09-10-2015 06:37 PM
ahsm
09-09-2015 08:35 AM
