Power Steering Leak 2007 TSX
Old 01-31-2017, 05:49 PM
07tsxowner's Avatar
Car has 91k miles and I got an estimate for $3100 for leaky rack &pinion plus $1600 for power steering pump. Is it worth fixing?
Old 02-02-2017, 08:51 AM
TexasHonda's Avatar
Leaking rack. How badly? Some leaks respond to Lucas PS Leak Stop. Worth a try.
A rack replacement is a fairly extensive repair, but not $3100 IMO. More like $1000-$1500.
PS Pump should be no more than $250 including pump. An easy job. Not necessary unless pump is not pumping.
Suggest getting estimates from another shop.
good luck
Old 02-02-2017, 09:00 AM
Received 8,711 Likes on 6,718 Posts
Sounds like you're getting thrown into the ringer... Are they sure the rack is leaking and not just the PS pump PS pump can be had for a few hundred and then add an hour or two for labor..
Old 02-08-2017, 12:04 PM
mrgold35
mrgold35's Avatar
Received 1,530 Likes on 1,193 Posts
Went in for an A1 service on my 06 TSX with +136,000 miles and Acura told me my power steering pump was leaking. They gave me two alternatives of new OEM pump for $1000 parts/labor or aftermarket for $550 parts/labor. I found an used power steering pump from an 07 TSX with 70k (eBay, $100), purchased a new serpentine belt (Amazon, $18), and a bottle of Honda/Acura Power steering fluid ($6). Labor was 90 minutes at $90 per hour ($141 total) to install at a local performance shop. So far, so good; but, time will tell if this was a better deal or not.
I'm sure you can find a pump and rack on eBay.
Old 03-23-2017, 05:08 PM
3rd Gear
Karies's Avatar
I just had the same issue with my Car, Shop told me Leaking Rack but it was a leaking pressure line. simple repair and alot cheaper
Old 03-26-2017, 01:50 AM
3rd Gear
STREETFIGHTER50's Avatar
Wow $1600 to replace a PS pump?! GEEEZUS that sounds like highway robbery right there!
micro23
11-22-2016 04:19 PM
dudeinaTL
10-28-2016 01:03 PM
Vtbx
1G RDX (2007-2012)
10-24-2016 10:07 AM
shaselai
10-16-2016 04:33 PM
500e
3G RLX (2013+)
10-15-2016 06:17 PM
Quick Reply: Power Steering Leak 2007 TSX
