Pop when jacking up my car
Old Aug 8, 2005 | 02:54 PM
TSX.Fury's Avatar
send me a link to JDM??
So question...
I was jacking up my car and there was this really loud pop. Like I'm talking gunshot loud pop. I lowered the car like immediately and drove it around. Everything seems to be totally fine, the ride isnt worse and the tire is fine. I don't know it I'm imagining it but the road noise might be louder, although I could just be listening harder. Anything this could have been that I should get checked out? It scared the shit out of me...
Old Aug 8, 2005 | 03:10 PM
jlukja's Avatar
Which end were you jacking up? I.e. which wheels were still on the ground?
Old Aug 8, 2005 | 03:13 PM
TSX.Fury's Avatar
front right... back and front left were still on the ground. The wheel I was jacking up was still resting on the ground as well.
Old Aug 8, 2005 | 03:20 PM
jlukja's Avatar
Hmmm, maybe just normal suspension creak with the weight being unloaded from the springs and being shifted to the left front? At least, that would be my guess. The suspension takes a bit more flex in this way. I'm usually using the jack point in the middle (front or back) with both wheels going up at the same time.
Old Aug 8, 2005 | 03:21 PM
YOTH's Avatar
Thriller
Did u check the jack itself?
If you jacked it up correctly there should not be any points that would be overstressed to do that.
Old Aug 8, 2005 | 03:22 PM
TSX.Fury's Avatar
not at all like the normal creaks and cracks I hear when jacking up... I mean this was seriously loud. But I guess I'm not super worried cause the car seems to be running fine. I mean, I don't think anything is critical at least.
Old Aug 8, 2005 | 03:24 PM
TSX.Fury's Avatar
that's what I'm thinking... that it could have been the jack. Sometimes they pop etc.
Don't know what you mean about points being overstressed... this happend in the process of jacking it up, didn't have it all the way up yet. Sorry if I didnt clarify that.
Old Aug 8, 2005 | 03:33 PM
YOTH's Avatar
Thriller
Points of stress would be the suspension and even maybe the transmission as they are taking on the extra load with that wheel being jacked up. If you didn't block your rear wheels, there's always a possibility that the car shifted a bit.
Old Aug 8, 2005 | 03:52 PM
TSX.Fury's Avatar
hmmm gotcha... thanks!
Old Aug 8, 2005 | 03:55 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Do you have coilovers?
When you jack the car up high the spring might be becoming unseated.
Old Aug 8, 2005 | 03:56 PM
TSX.Fury's Avatar
yeah... and true. But would that cause that kind of a pop? I didn't think so...
Old Aug 8, 2005 | 04:31 PM
Howard911s's Avatar
HOWARD911S
how about when u jack it up. the jack and bottom of the car was not 100% fitted and the car slid just that tiny bit you cant see, but caused that noise? that happened to me before when i was jacking up my friends lexus
Old Aug 8, 2005 | 05:41 PM
JTso's Avatar
If the spring preload setting is adjusted correctly, the spring should never come off the spring perch when the car is lifted, unless one uses the spring perch to lower the car past the initial preload height.
Old Aug 8, 2005 | 05:59 PM
pizzaman555's Avatar
the jack most likely was sliding just a bit did it with my car to
Old Aug 9, 2005 | 01:10 AM
aaronng's Avatar
Driver/Detailer
It's the spring extending. I get that loud pop sound too, not only with the Accord Euro, but with a 94' Accord other brands (Mitsubishi).
Old Aug 9, 2005 | 01:39 PM
TSXDude's Avatar
Noobie 6MT driver
I get this rather loud "pop" too when i jack up my car. I cant' recall if this happens everytime, but i usually ignore it.
Old Aug 9, 2005 | 05:55 PM
pcaulfie's Avatar
Same here...jacking up the front right and the same pop. Freaked me out at first, but all is still well with the car.
Old Aug 9, 2005 | 09:16 PM
GotdatTSX's Avatar
Could be a broken rear end link. Mines made a loud popping sound while I was turning into a drive. I took it to the dealer and sure enough, my left rear end link had snapped in half.
Old Aug 9, 2005 | 10:20 PM
TSX.Fury's Avatar
what would you feel because of this? Cause I am def thinking the road noise might be alot louder... but other then that I don't really feel anything.
Old Aug 10, 2005 | 02:53 PM
TSX.Fury's Avatar
anyone? what effects would I see/feel/hear from a broken end link?
Old Aug 10, 2005 | 03:32 PM
TSXDude's Avatar
Noobie 6MT driver
I have not personally experience this, but in terms of feel, i would guess you car will be very unstable when you are making a hard turn.
You can always check the endlink by crawling underneath the car and inspect them yourself.
Old Aug 10, 2005 | 06:10 PM
GotdatTSX's Avatar
There was a slight metal to metal tapping sound whenever I made turns that had dips (high driveways, corners with dips,etc). Also, it won't feel as tight while making turns on streets or curves on freeways.
Feb 25, 2020 09:57 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
Phambam12
Sep 6, 2015 06:57 PM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
