Please verify my compressor is locked up
Old Jun 4, 2013 | 07:32 AM
charlie.n.hill's Avatar
9th Gear
Below is a video, towards the top is my botched compressor. This is with AC on. A month ago, I put the car in reverse and heard a loud rattling noise, then it stopped and slowly the cold air stopped. I know this is a common problem as I have done a lot of searching on the board, I just don't have another TSX to compare. I'm pretty sure the clutch isn't spinning. Can you verify from the video?
Sounds from my searching like there is a possibility that the compressor blew and contaminated the entire system.
With that and the upcoming CV joint replacement due to acceleration vibrations, I'm likely going to dump this car.
Old Jun 4, 2013 | 09:51 AM
gideon's_test's Avatar
Well, from what I can see in the video, the compressor doesn't appear to be spinning.
What you can do to verify, is with the car off, reach down there and see if you can turn the compressor by hand (the face of the pulley, not the edges where the belt is). If it does not turn by hand (it should if the compressor is ok), then your compressor is toast.
If it does turn by hand, then there are several possibilities:
1) clutch is bad
2) freon is low, system is preventing clutch from engaging to preserve the pump
MrHeeltoe
20
Feb 23, 2023 01:54 PM
soupi
14
Nov 15, 2015 11:15 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
