Please Help!!! Key Fob, windows and door lock not working.
Old Jan 1, 2018 | 09:31 AM
Enorec's Avatar
Long story short I had both my drivers’ side doors replaced. When I got the car back my key fob wasn’t linked to the car. I performed the sync procedure and the fob would connect while inside the car. Doors would lock and unlock and trunk would open, but as soon I would opened the front door it would no longer be connected. So I would have to lock and unlike the car manually. For the last three weeks the power windows would work inside the car up until two days ago. The drivers’ door panel wont lock doors or roll down any windows. It will adjust the passenger side mirror but not the drivers side mirror. The passenger’s side lock switch will lock and unlock all doors but passenger’s side window switch won’t roll down its window.
Old Jan 2, 2018 | 10:14 AM
TexasHonda's Avatar
Problem could be "soft", related to a difference in driver's door panel on replacement door. Circuit diagram doesn't show differences for model yrs 04-07.
Problem could be wiring defect. Suggest inspecting the driver's door wiring and door jumper (door to body) for damage.
A Honda Diagnostic System (HDS) is necessary to interrogate the BCAN system for faults. A shop w/ this capability may be necessary.
good luck
Old Jan 10, 2018 | 02:31 PM
Enorec's Avatar
When they replaced the interior driver's panel I'm assuming they put the door/window assembly switch from the other car. The part number is 35750-SEC-A02. Well that part is not compatible with my vin. I'm told I need a 35750-SEC-A03. The upgraded part being 35750-SEC-306. I'm going to order the new part and pray that it works.
Old Jan 22, 2018 | 03:55 PM
redpoint's Avatar
Check fuse 7 too. Be prepared to re-enter the nav code because I think pulling the fuse loses the nav memory.
Negative1
May 11, 2014 11:53 AM
Sgt128
3G MDX (2014-2020)
Feb 23, 2014 09:39 AM
thisaznboi88
Nov 10, 2013 10:39 PM
thedavej2001
1G TSX Problems & Fixes
Dec 6, 2012 04:07 AM
briancl
2G CL Problems & Fixes
Oct 15, 2012 05:04 PM
