playing burned cds
Old Apr 5, 2007 | 07:48 PM
nnd1289's Avatar
playing burned cds
I was wondering if everyone else is having a problem playing burned cds in their TSX. I just got mine and it keeps on making static noises.The people at Acura said it was because I play burned cds, but one of my friends just got his TSX too and he has no problem with playing burned cds.
Old Apr 5, 2007 | 08:02 PM
NJSGTI's Avatar
Ive played them in mine before and they worked fine.
Old Apr 5, 2007 | 08:03 PM
gavinn58's Avatar
STi'd
i pretty much only play burned cds
Old Apr 5, 2007 | 08:18 PM
RooDHawG's Avatar
RooDHawG
Old Apr 5, 2007 | 09:12 PM
visuelz's Avatar
East Coast Crew
Does anyone have problems with burning cds such as skipping?
Old Apr 5, 2007 | 09:33 PM
TSX2345's Avatar
A DiRTBAG decal on my
Works fine for me
TSX420J's Avatar
CarbonGreyPearlEbony
I get that a lot, but I think that my burner is old because it never did it.
Old Apr 5, 2007 | 10:15 PM
drigo's Avatar
i play 90% burned cd's on mine with no problems...what speed are you burning your cd's? try using a slow speed ...
Old Apr 5, 2007 | 10:38 PM
visuelz's Avatar
East Coast Crew
I burn at 4x with nero. That's the slowest I can do. Maybe it's the media or the device?
Old Apr 5, 2007 | 10:42 PM
drigo's Avatar
4x should be fine...have you tried roxio? i use the cheap comp usa brand cd-r's
Old Apr 5, 2007 | 11:10 PM
visuelz's Avatar
East Coast Crew
Hmm...I'll look into roxio. Thanks
Old Apr 6, 2007 | 01:54 AM
subdued's Avatar
my acura sanctuary
nnd1298, did you confirm that you can play those burned CDs that they also won't play in a home stereo or boombox? ...something other than a PC?
I have a feeling your burned CDs do not have AIFF format (standard audio format) music files. The TSX stock stereo will not play CDs burned with WAV, AAC or MP3, etc files.
Yes, I can play burned CDs with AIFF (AIF) format music files on my TSX.
Old Apr 6, 2007 | 10:04 AM
alucardx's Avatar
i've gotten constant static noise with no vocal/music present on burns where i had CD-TEXT checked (in nero) whether i put CDTEXT info in or not. check this setting out on your nero before you burn it.
Old Apr 6, 2007 | 11:42 AM
Tumby's Avatar
Be sure your chk the speed on the CD that you used as well... for example... if the speed of the disc can takes up to 4x but you burn the songs by speeding up to 8x then it will cause the static... I had done this before and that explain the cause.
Old Apr 6, 2007 | 12:04 PM
Fox137's Avatar
If you are using Nero to burn your music cd's... try looking up the Nero 7 audio cd skipping fix ... i had the same skipping problem with burning cd's from mp3s till I got this fix
google it
Old Apr 6, 2007 | 03:28 PM
TSX420J's Avatar
google it
That is probably what I have, but I also get that static sound.
Old Apr 6, 2007 | 03:30 PM
jaehshim's Avatar
i only play burned CD and MP3 from PSP that's connected to Auxillary.
i burn CD at 16X, and has no problem playing all the songs.
Old Apr 6, 2007 | 04:58 PM
dP-'s Avatar
dP-
I have this problem as well...I've been burning at 1X...
Old Apr 6, 2007 | 05:07 PM
TacoBellSauce's Avatar
u shouldnt have this issue if u use nero 7 to burn CDs
i also noticed that CDs burnt with the sonic software that comes standard with the dell laptops sometimes wont work
Old Apr 6, 2007 | 06:25 PM
dnd2984's Avatar
Maybe because you are a idiot, thats probally why you get static....And when did u turn 18?
Old Apr 6, 2007 | 06:28 PM
dnd2984's Avatar
^ J/K he is my brother. Welcome him to the forum....
Yea so Acura gave us a story on how its the burned CDs. I dont believe it because I am pretty sure that the factory unit is man. by either Alpine or Pioneer.
Hmmm never thought about the burning speed
Old Apr 11, 2007 | 09:44 AM
tsxmike's Avatar
Welcome to the forum!
Yeah I do get a probelm with burned cd's sometimes it skips or does not play at all. But I think it is because of my burning software or old cd burner. I got some new software and new cd/dvd burner so I am going to try it out.
Old Apr 11, 2007 | 12:20 PM
dereksmalls's Avatar
talk about mudflaps....
I've had no issues with CDs burnt with Sonic software.
There are tons of variables with burning discs. It may even come down to the burner itself.
Old Apr 25, 2007 | 10:27 PM
TSX420J's Avatar
just did the nero fix.
I did some research and found this link http://www.cd-burner-help.com/nero-skipping.htm that has the files that are needed to fix the problem. So far so good. I just removed the files and replaced them with the ones in the link. Scroll to the bottom to see the link for the download.
Old Apr 26, 2007 | 07:44 AM
jswim99's Avatar
What makes you think that it's manufactured by those companies? I would expect a japanese car to have japanese electronics, like Matsushita or something. I know japanese auto parts companies like Denso make the navi units, so why not the stereos?
Old Apr 26, 2007 | 01:54 PM
user 452786420's Avatar
it is the burning speed, it is not acura, or alpine or anyone else, its you.
if you try and burn an audio cd at the fastest possible speed vs burning at a slower speed there is going to be difference in quality. i thought everyone knew this but apparently not, if you are having static on your cd than stop burning at the fastest speed.
it depends on the burner and software but some people with prehistoric or so-so quality burners will have more of a problem with this and will need to burn at a slower speed
Old Apr 26, 2007 | 02:05 PM
AirJordan23922's Avatar
yeah i have the problem and it's annoying as hell and now it's starting to carry onto brand new non burned cd's....maybe the burned discs somehow messed up the lens or whatever reads the disc
Old Apr 26, 2007 | 03:14 PM
cpone's Avatar
It can be burn speed, quality of the burner and/or the quality of the cds. Most work in my TSX, while others experience problems, with the only variable being the CD-Rs used.
Old May 2, 2007 | 08:27 PM
dnd2984's Avatar
Casue thats what it is.
Old May 2, 2007 | 08:29 PM
dnd2984's Avatar
Hi ass, It happens on new cds to. I tried playin with it and made a cd at 4x and still no luck. I am just gonna have acura replace the unit.
Old May 2, 2007 | 09:56 PM
TSX420J's Avatar
You know what is funny, the other day I was installing new driver for my computer
and found out that the burner that came with my vaio (pioneer dvd-rw) had a
problem with the firmware that made it sound like static sometimes while the
cd was playing on other sources. I dunno if it is coincidence but it is true. I also fixed the skipping when I replaced the DLL's in nero. I wouldnt take it back. I swear I
have the static problem. Another thing is the burner I have is also in HP computers too. Maybe you have the same burner.
Old May 10, 2007 | 08:16 PM
bpgruber's Avatar
My son's 04 TSX wouldn't play the burned CDs properly. At first I got the line about burned CDs, so I put them in his mom's 04 TSX and they worked fine. I explained this to the service rep. and he replaced the player under warranty; it works fine. It nice to have 2 of the same exact cars.
Old May 11, 2007 | 12:55 PM
TSX420J's Avatar
Just heard some static, even with my new burner. It is the radio. I didnt even burn it with nero. Great, now I have to take it to the morons at the dealer.
Old May 25, 2007 | 07:29 PM
abqtsx's Avatar
Glad you got it fixed! I've had zero problems with playing burned CD's in my '04. I'm pretty sure that our players are Pioneer units - one of the Acura mechanics told me that, but I'm adding a USA Spec adapter soon, and I'll see if the unit has any brand markings. The rear deck 6x9 speakers are Pioneers. I believe the add-on MP3 player is also a Pioneer. FYI jswim99 - Pioneer and Alpine are both Japanese companies.
calrow
May 3, 2017 10:21 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
Thuneau
Oct 3, 2015 04:19 PM
hashbrown
Sep 29, 2015 12:13 PM
