p2101 error
Old Sep 29, 2012 | 06:51 PM
ludespeedny's Avatar
p2101 error
Today I was driving along and the check engine light came on, the VSX light, and the triangle with an exclamation point lights came on. I didn't have any acceleration. I pulled over turned off the car, turned it back on and was able to drive back home.
I got the p2101 code. And proceeded to clean the intake as mentioned in another thread with deep creep and seafoam.
I noticed that when I turn on the ignition that my butterfly valve doesn't open, it looks like it tries to move bot doesn't. I am able to push the gas pedal and it will open completely. Is this normal?
Do you know what else I should do? I am about to drive around again after doing the seafoam.
Old Sep 29, 2012 | 09:27 PM
RA032025's Avatar
in the 24th and a half...
P2101: "Throttle Actuator System Malfunction"
The troubleshooting process likes the cleanin of the throttle body, but calls for smooth operation of the valve after cleaning. Can't answer the position question properly, but on start the mixture should be rich, which would call for limited air flow. This would suggest the throttle valve should be closed and then open normally with gas application.
phillyguerrilla
Sep 26, 2015 11:27 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
mikeytown2
Sep 21, 2015 12:41 PM
Big mo
4G TL Problems & Fixes
Sep 12, 2015 07:22 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
