Oxidized chrome grill
Old Aug 31, 2003 | 08:10 PM
Fooman's Avatar
There is a spot on the chrome front grill that appears "oxidized" and no matter how I clean it, the same spot always returns. I don't have a pic of it, but the spot is located on the top part of the grill where it meets the front hood. I've been using a cleaner/wax to remove it and it works, but it comes back again.
Anyone else notice this and any suggestions?
Old Sep 1, 2003 | 01:34 PM
MikeMa's Avatar
No Longer a Poseur
Re: Oxidized chrome grill
If you used the combo cleaner and wax in one, I'd like to suggest you move to the Quick Detailer/Clay bar. Then use either step 2 in the Meguiar's or Mother's 3 step system (or whatever the Zaino equivalent is). Finish it off with a couple coats of wax (or, again, the Zaino equivalent).
I'm just wondering if the cleaner/wax isn't
a) picking up the oxidization well enough and;
b) not providing enough wax protection.
Good Luck!
Old Sep 1, 2003 | 02:46 PM
Encyclo's Avatar
Cool
Here is my suggestion; dosen't involve any fancy waxing products or anything: go to your deealer and have it replaced
You have a warranty against corrosion... and this is corrosion. Should be replaced no charge.
Old Sep 1, 2003 | 11:31 PM
MikeMa's Avatar
No Longer a Poseur
Good point!
I guess I'm just more of a try to fix it yourself guy (although, anything beyond my capablility (like replacing a rim, or whatever), I definitely go to the dealership.
Old Sep 3, 2003 | 10:40 PM
Fooman's Avatar
I went to the dealership today and they said they will replace the part under warranty. Upon closer inspection, it appears that the particular spot was extremely flushed with the hood of the car while the rest had a tiny gap. It probably turned that color due to the extreme heat of the hood.
Old Sep 4, 2003 | 06:36 AM
Encyclo's Avatar
Hey, that's the Honda/Acura I know
Glad to see it worked out.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
rhdune16
Sep 28, 2015 11:31 AM
