Oil Pan Leak
Old Dec 26, 2004 | 04:14 PM
InsuranceGuy's Avatar
Oil Pan Leak
Okay fellow TSX'ers. I took my ride to the dealer for the first oil change and was told that I had an oil leak coming from my oil pan. While the dealer was quick to advise me that all of the work was going to be covered by warranty they gave little to no explanation as to why the leak had occured. I have not hit anything to my knowledge but wanted to see if anyone else has experienced the same kind of problem. The dealer of course said this was the first time they had seen this. Not an oil leak but on a TSX oil pan.
Thoughts??
Old Dec 26, 2004 | 04:20 PM
jmathew34's Avatar
could be a possibly bad oil pan gasket, but I don't see how it could be bad since your car is so new and this is your first oil change. i changed the oil pan gasket in my 97 accord around 90k miles, but that was due to wear and tear.
if i were you i would ask your service advisor for an explanation, i think they are required to tell you and it should also be noted on your invoice you recieve.
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Avenger411
Oct 11, 2015 03:53 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
