oil consumption problems
Old Jan 12, 2006 | 12:27 PM
  #41
batboyvaj's Avatar
hey...i had a thought....
how many of you burning oil are using a synthetic like mobil 1. and how many are using the old dino stuff.
Old Jan 12, 2006 | 01:27 PM
  #42
moda_way's Avatar
Mobil1 and no burning... 48k miles and I hit the redline at least once a day.
Old Jan 12, 2006 | 02:19 PM
  #43
waTSX's Avatar
Have camera, will travel
Originally Posted by HoRRo
Ah, the F430 is one sexy beast, my fav. Ferrari, esp. in the dark grey
Yowsa!
Old Jan 12, 2006 | 02:23 PM
  #44
waTSX's Avatar
I switched to Mobil 1 last oil change, about 11,000 miles on the odo, then checked the level ~2700 miles into the change. I was about 1/3 quart low, which I don't consider significant.
I've been revving it pretty good since Hondata
Old Jan 12, 2006 | 06:02 PM
  #45
aaronng's Avatar
Driver/Detailer
Full synthetic, Castrol Formula R 0w-40. No oil consumption. Oil level on the dipstick doesn't change between service intervals.
Old Jan 12, 2006 | 07:21 PM
  #46
curls's Avatar
Someone stole "My Garage"
Originally Posted by curls
All I know is that today I brought it in, they didnt open anything up, but ordered a new set of rings and a valve kit (seals and guides). They ordered a master gasket set but it was backordered, so I might get the car back until it comes in (they will know more tomorrow (Tuesday)).
Either way, they're doing both rings and valve seals/guides, but are definately looking for the ACTUAL cause of the problem. I will definately report back.
Well, the gasket kit is backordered for 7-10 days, so I have the TSX back for now and will be bringing it in in about 2 weeks once all the parts are there and ready to rock.
Old Jan 13, 2006 | 11:58 AM
  #47
wiz's Avatar
wiz
I've noticed lately that my 04 TSX with 44k miles on it is starting to drink about 1.5 quarts of oil in between oil changes. I'm going to bring it up at my next oil change next week and see what they have to say about it.
Old Jan 16, 2006 | 12:49 PM
  #48
batboyvaj's Avatar
you are almost at that magical 50k
Old Jan 16, 2006 | 07:16 PM
  #49
aaronng's Avatar
Driver/Detailer
Remember to top up with oil to keep the level above minimum. Call them first and let them know that your car is drinking oil. Ask if it will affect their monitoring if you top up with oil.
Old Jan 29, 2006 | 09:00 AM
  #50
Bullzeye's Avatar
Fiber Reinforced Liner (FRL)
---------- Does anyone know if the TSX uses this type liner as to my understanding it was used in the 96 gen Prelude and the NSX?
Cutting edge design which used a Carbon fiber liner with aluminum oxide. The fiber was like swiss cheese coated with aluminum oxide. Carbon fiber is born/processed at around 2600 C - 3000 C while the oxide is stable at temps of around 3000-3600 C. It's basicly that grey film that develops on aluminum.
These combined make for a very tough/rigid liner. When you force the aluminum through the liner (swiss cheese)while forging the block you end up with a block that is rigid from the inside out with good heat transfer and keep the weight down.
Cast Iron blocks have been the norm in trucks forever because the strength and rigidity it brings. If I understand this correctly they pioneered this in the F1 arena along with the Double Wishbone and filtered it to production.
Old V-8 engines of 25-30 years ago would have a ridge in the top of the bore after about 70K miles that wouldn't allow removal of the piston without removing the ridge first. The japanese added I was told about 5% nickel to be able to get 200K+ miles from a cast iron block.
First post and I'm already rambling, please excuse but I've read of similar complaints of the Prelude using this FRL. Breakin sounds more crucial to them.
I'm currently driving a 92 Prelude with 215K+ miles, my daily beater.(64miles a day, 70-80mph 90%C/10%H 25mpg av.) I run Amsoil 10W30(synthetic) in the engine and the transmission(auto) and change them both at around 12-13K miles. I'm looking at the 06 Civic EX auto or a used TSX to replace it. Man I like the TSX a bunch but I like the economy of the Civic.
-------That brings me to my other question of what kind of fuel economy you get C/H %/%?
BTW I don't add a whole quart between intervals.
Regards
Bullzeye
Old Jan 29, 2006 | 09:49 AM
  #51
curls's Avatar
Regards
Bullzeye
Old Jan 29, 2006 | 09:01 PM
  #52
Bullzeye's Avatar
Sorry Curls
I'm runnin 90% Highway miles and 10% city to get an average of 25 mpg. Sorry for the confusion
Old Jan 29, 2006 | 09:22 PM
  #53
aaronng's Avatar
Driver/Detailer
Nope, the TSX has iron liners.
Old Jan 29, 2006 | 09:40 PM
  #54
sauceman's Avatar
Moderator Alumnus
Sorry Curls
You'll get a lot better than that with the TSX.
Old Jan 30, 2006 | 05:45 PM
  #55
curls's Avatar
OK, got a call from Camco Acura. Car is going in Wednesday morning and should be back Friday afternoon.
Turns out they're not authorized by Acura Canada to do the valve seals/guides unless they are out of spec, so they should be checking that while they're in there.
They ordered and have ready:
- piston ring set
- timing chain
- timing chain tensioner
- master gasket kit
- head bolts
Woooooo!!!!
Old Feb 7, 2006 | 02:33 PM
  #56
curls's Avatar
Update on my situation;
https://acurazine.com/forums/showthread.php?t=28541
mada51589
Jan 9, 2025 04:40 PM
robm
Sep 18, 2015 07:53 AM
pizokk1
Sep 17, 2015 09:29 AM
HydrasunGQ
Sep 14, 2015 10:14 PM
jfman55
Sep 5, 2015 02:55 PM
