Not able to customize Multi-Information Display
Old Apr 17, 2008 | 03:13 PM
kwyatt318's Avatar
My Multi-Information Display says "Driver unknown'customize' impossible" even though i use my remote transmitter to unlock my doors. Has anyone ever had this problem or knows how to fix it?
Old Apr 17, 2008 | 04:49 PM
hunterk1's Avatar
Poser / Fanboi
You have to link the key FOB to your car.
Read the white text on the back side of the key FOB.
Old Apr 17, 2008 | 05:31 PM
White92's Avatar
Is this done by the dealer?
Old Apr 18, 2008 | 10:50 AM
SoCaliTrojan's Avatar
Let me help you!
The white text will tell you to push the lock and unlock button together at the same time. I suppose you can drive it over to the dealer so they can push the two buttons together for you...
Anyway, after both buttons are pressed, the FOB is linked to the car, and then the settings can be changed. Until they are linked, the car doesn't know whether to set the settings for Driver 1 or Driver 2. I think basically it turns on/off the transmission of whether the remote is Driver 1 or Driver 2 (the remotes still work if the FOB's are unlinked...and TSX's without memory link can only use the remote if it's left unlinked).
Old Apr 18, 2008 | 04:13 PM
cwinterrowd's Avatar
I had a lot of trouble getting this working too.. I think the manual says to push both the lock & unlock at the same time until the light blinks twice, open and close the drivers side door, lock and unlock the car with the remote, and you should see "Welcome Driver 1" after you turn the ignition on.. you only see "Welcome" when you open the door and will not see "Driver 1/2" until you turn the ignition on.
What I found was that if the remote blinked twice, it was unlinking the remote.. if I repeated the procedure and it gave me a single blink, it was linked. Honestly, I thought the manual could be a little bit clearer on this. I also looked for details on this in the 2000+ page service manual, and the only thing I was able to find was how to get the car to recognize a new/replacement remote transmitter, and it was only half of a page.
Old Apr 18, 2008 | 05:57 PM
hunterk1's Avatar
Poser / Fanboi
Originally Posted by cwinterrowd
I had a lot of trouble getting this working too..[...]
It definitely isn't as straightforward as it could be. I remember pushing the buttons together, getting in the car and seeing if it took, it didn't, trying again... and again... and again... yeah, the single/double blink is what you're looking for (on the remote - that little tiny light).
Old Apr 19, 2008 | 11:47 AM
kwyatt318's Avatar
lol i went to the dealer and they linked it up in minutes. they said a lot of people have trouble doing it because the manual is not very clear
Old Apr 19, 2008 | 09:44 PM
davidspalding's Avatar
Make a hole, coming thru!
Also, as per p. 85 (of the 2006 manual), if you use the key to open the driver's door, you get the DRIVER UNKNOWN "CUSTOMIZE" IMPOSSIBLE (an awkward error message if I say so).
Old Apr 20, 2008 | 12:20 AM
TS_eXpeed's Avatar
I wish you could get the MID to say 'Hello, (name)' in there instead of 'Driver 1', lol
Old Apr 20, 2008 | 03:34 PM
hunterk1's Avatar
Poser / Fanboi
(With apologies to "dave"spalding)
Dave: Hello, TSX, do you read me, TSX?
TSX: Affirmative, Dave, I read you.
Dave: Open the driver's side door, TSX.
TSX: I'm sorry Dave, I'm afraid I can't do that.
Dave: What's the problem?
TSX: I think you know what the problem is just as well as I do.
(...it could go on, but that's enough...)
Old Apr 20, 2008 | 03:58 PM
^ Bastard beat me to it....
"Alright, HAL. I'll go in through the emergency trunk release."
"Without your LED key fob, Dave, you're going to find that rather difficult...."
I've been tempted to print up the Zero Gravity Toilet instructions as an aluminum label. As it is, I have a couple of aluminum vinyl labels I've bought off a Star Trek senior illustrator, just looking for a place to put one. "Danger: Plasma Manifold" over the not an ashtray?
Old Apr 20, 2008 | 04:05 PM
I'd settle for
Good Morning
Captain
Old Apr 20, 2008 | 04:11 PM
hunterk1's Avatar
Poser / Fanboi
Good stuff.
Seems like others have broken into the navi and made customizations... I wonder where the text for the MID is stored? If you could find it and it was on rewritable flash memory it could be updated... I don't have the time to pursue this though but it would be a fun (and probably free) mod!
Old Oct 5, 2010 | 12:43 PM
jfintexas's Avatar
8th Gear
It worked!
cwinterrowd, your instructions worked perfectly. Thanks for posting!
Old May 28, 2016 | 08:06 PM
Oisbuddy's Avatar
Thank you, thank you, thank you
I have wasted two entire days trying to figure this out. Your method finally worked. Thanks!
Old May 22, 2020 | 07:06 PM
jamie johnson's Avatar
fobs don't blink when I press lock/unlock
I'm trying tofto get my06 tsx todto recognize driver 1 or 2 so ibI can get into the customizing menu .I press lock/unlock together on either of my key fobs and nothing. No blinks at all when both are pressed. Both fobs work fine to look or unlock the doors and roll down the windows ECT. But I've been trying to get this to work for days I've searched everywhere I can find . Does anyone else have this issue? Or is there something broken somewhere? I've also found that my hfl Bluetooth it now functional. When I press the back or ,talk buttons once/together/for 5 or 10 seconds .. And a dozen other ways I've got nothing. Any advice?
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
Froid
Sep 27, 2015 06:16 PM
dirleton
Sep 25, 2015 12:25 AM
