Is this normal brake wear?
Old Jun 9, 2013 | 08:28 PM
Braz60's Avatar
Today I changed my rear brake pads and rotors on my 2006 TSX with 54K miles on it the rotors looked decent but both my rear inner pads had unusual wear The wear is tapered attached is a couple of pictures. Your thoughts
Attached Thumbnails Is this normal brake wear?-rear-pad_1.jpg   Is this normal brake wear?-rear-pad_2.jpg
Old Jun 9, 2013 | 08:30 PM
kbh's Avatar
kbh
Your pads were likely not properly installed in the caliper or bedded in.
Old Jun 10, 2013 | 07:30 AM
TexasHonda's Avatar
This happens when the pads are not aligned to the caliper piston grooves. One side is cocked.
If you installed, you may need to check your new pads for same problem. The pads have a small nib and pistons have a groove that need to be aligned for proper pad fit.
good luck
Old Jun 10, 2013 | 10:07 AM
Braz60's Avatar
good luck
Thanks that's a good point.
I didn't think of that, first time working with these type of rear brakes that the calipers screw in I'm used to compressing the caliper with a "C" clamp I will have to recheck my pads.
Old Jun 10, 2013 | 10:27 AM
Braz60's Avatar
good luck
Braz60's Avatar
How does this type of caliper piston work? if it screws in what happens when you apply the brakes does it scew out to compress the pads? That doesn't make sense to me it seems like this would twist the inboard pads.
Old Jun 10, 2013 | 08:05 PM
Braz60's Avatar
I googled how the rear brakes of our type work now I have a better understanding the screw type piston in the caliper is more for the emergency brake. I checked my brake job and everything lined up.
Thanks for everyone's help
SidhuSaaB
May 30, 2020 12:40 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
mellsonnj
Sep 24, 2015 04:42 PM
