Noise from Powertrain
Hi all,
I have a 05 TSX and I heard some noise from the front of my car when it is acceleating slowly. At first, I through I am too sensitive but even my friends can hear the same noise. It is kindda like virbating noise from the exhaust or something and it will get faster on the virbation when the speed start picking up. However, you won't hear anything if you are stepping on the gas padel hard.
Have you all ever have this problem on your TSX??? Please give me some hints if so... as I took it to the dealer but they can't find SH*T and that really piss me off!!!!
Thanks all!!!
Thanks all!!!
Yeap....... the guy who test drove w/ me is actually a mechanic w/ Honda.... but at the time when we did the test drive.... the frigging noise didn't come up and I thought I was too sensitive. But again..... the noise is so obvious that even my friends could hear it during the ride.......
I really need some help to see whether someone can give me an idea.
sigh........
sigh........
ok... I dunno whether you guys can give me any suggestions..... I ran a test drive w/ a machanic last week when they through the noise was from the heat shield on the exhaust or from the alignment but it wasn't after they replaced the heat shield and adjustment the alignment at my own cost. I ran a test drive w/ a machanic and he caught the noise as well.... then I drop my car at the dealership again for 2 fucking days this week and they suggested it is probably from the break rusty rotor and brake pad; or the shaft of the front wheels..... I pick it up tonite after work,.,,, and of course.... no more machanic are still at the dealer.... the rumbling noise is still there even after they replace a new brake pad and rotors at the front, plus polished the axial.... I really have no clue what else could it be.... I need to go back to the dealer again for sure but I dunno whether they will still try to find the source of the noise after they put soooooo fucking much time on my car. >.<
Any suggestion will be greatly appreciated.
and btw.... what might cause the steering shacking while traveling around 110 km/h or above if nothing wrong w. the alignment nor the tire balancing??? This is what happened to my TSX regardless what they have done to try to fix my car in the past couple of times....
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
