New wheel bearings?
Old Aug 8, 2009 | 09:38 PM
supraken's Avatar
New wheel bearings?
I'm starting to hear what sounds like a wheel bearing noise on my '04, it's that whoomp-whoomp-whoomp sound that's speed sensitive. I think it's isolated to the front driver's side wheel. I hit a pothole a few years ago so it might make sense...
Anyway, any suggestion on where I can get the wheel bearing? Any difference if I buy OEM or aftermarket? I was planning to just take it to a local shop and let them take care of it, but was thinking if it's better if I get the OEM part and have the install it.
If I get the OEM part, is the wheel bearing the only thing I need to buy? For example, in this diagram is #6 the only thing that I need?
http://www.hondapartsunlimited.com/p...=FRONT%20BRAKE
Old Aug 8, 2009 | 09:39 PM
supraken's Avatar
Also, would it make sense for me to also change anything else while I'm at it?
Old Aug 9, 2009 | 02:31 PM
gasser's Avatar
I've already changed 2 rear wheel bearings since I bought my car, it was the only part that I needed. The guy I bought these parts from recommended OEM ones, suggesting that they could last longer.
Old Aug 11, 2009 | 05:00 PM
TSX7's Avatar
I had the same problem but it wasn't the bearings (also front driver side).....I recently had brake rotors/pads replaced and it disappeared.
Old Aug 12, 2009 | 10:35 PM
supraken's Avatar
^ Interesting... maybe I should wait until I replace the rotors first since I'm planning to replace the rotors soon anyway..
Old Aug 14, 2009 | 04:52 PM
super4's Avatar
ye that whooomp noise is likely the rotors. but if u hear them more when turning its the tie rods (or CV joints), i forget lol.
to check what the problem is jack up the corner that you hear it on so that wheel is off the ground. have someone hold the steering wheel tight, then try to shake the wheel at 12 and 6 oclock. it should be firm and not move, if it does i think its the bearing. then shake the wheek at 9 and 3 oclock, if it shakes its the tie rods/cv joints (which make that kind of noise). if its all solid then rotors.
i had this problem with my last car, turned out to be just heat shield bent up behind the rotor.
Old Aug 14, 2009 | 09:06 PM
JB08's Avatar
One other possibility to consider is uneven tire wear. It too is speed sensitive and will make a pronounced sound at higher speeds. Rule out your tires before spending good money to have someone poke around....
Old Aug 29, 2009 | 09:09 AM
crcendo's Avatar
I believe you and I have the same issue. Whoop whoop sound at parking lot speeds that seems like it is coming from the passenger front wheel. When I release the accelerator it goes away. It does sound as if its rotating with the wheel whatever it is.
I have heard it could be transmission related, although my transmission shifts flawlessly.
Do you have an Auto or manual trans?
So far I have replaced:
Tires
Rotors/pads
New struts (disassembly did not reveal anything obvious in that area)
Old Aug 30, 2009 | 06:14 PM
Rocket_man's Avatar
Summer is Coming
I hear this sometimes on my 06 when I turn into my parking spot at work. It is a big left hand sweeping 270 deg turn and I sometimes hear a noise coming from the passenger side front wheel. Doesn't happen any other time.
Tires
Rotors/pads
Old Sep 2, 2009 | 08:12 AM
crcendo's Avatar
I have heard some people mention torque converter (automatic).
Thing is the transmission is on the opposite side, and I'm not hearing a noise from the driver side. So i'm kinda ruling this one out. I'm thinking now it could be vaccum as the noise is throttle dependent.
Old Sep 20, 2009 | 01:47 PM
crcendo's Avatar
I will be replacing the front wheel bearings soon to see if it cures my issue. Will let you guys know.
Old Sep 20, 2009 | 02:16 PM
DaChef320's Avatar
Registered Member
im having problem with my front passenger side and its only 1 year old car i got a appointment tomorrow to bring it back to the dealer... also my fuel cap senor is messed up
Old Oct 18, 2009 | 09:33 AM
crcendo's Avatar
I just replaced both of my front wheel bearings with OE parts.
The sound I could have sworn before was the right front could be in the rear. I drove the car with the seat folded down and that sound is clearly coming from the rear.
I will be replacing the right rear bearing in the near future. I cant imagine anything else that would be causing this fast pace woo woo noise back there. It seems to appear after turning, which if its the bearing makes sense. I have a slight squeek from back there as well when hitting certain bumps, but it should disappear after lubricating the RSB bushings.
Old Oct 25, 2009 | 10:25 AM
crcendo's Avatar
Can you describe the sound it made when you realized you needed to replaced your rear wheel bearings? Thanks!
Old Oct 27, 2009 | 10:39 AM
bmk04tsx's Avatar
My 04 TSX has this same sound except it is coming from my rear tires. You may want to stop by a reliable tire shop and have them look at your tires for signs of uneven wear, or cupping due to the lack of adjustable camber / caster on the rear. I just bought the Ingalls alignment kit for the rear of my car so that the rear alignment issues that affect TSX's will stop chewing up tires!
KB1_EJ6
Nov 13, 2016 09:51 PM
2012wagon
Sep 29, 2015 04:21 PM
real_mckoy
4G TL Problems & Fixes
Sep 25, 2015 10:49 PM
heyitsvic
Sep 4, 2015 09:38 AM
