Need to replace Clutch master and Slave again?
Old Oct 1, 2012 | 11:50 AM
TSXGOTME's Avatar
Hi guys I replaced my clutch, clutch master and slave back in April and seems like the clutch master is failing again thats only about 5000 miles. I’m getting a really bad click from the clutch pedal also sometimes I have to press the clutch pedal twice to put the car in to first gear and it also grids when I shift into reverse on occasion. My question is should I just replace the CM or CM and slave. Thanks
Old Oct 3, 2012 | 09:13 AM
78transam's Avatar
2005 TSX 6MT
Try bleeding the system again. I used a hand held vacuum pump when replacing the clutch MC on a Toyota. Bleeding won't fix the pedal click but worth doing.
Old Oct 22, 2012 | 01:08 PM
mike the texan's Avatar
My experience is that lubricating the pedal assembly might also be the problem. I do that regularly and the squeaking problem gets resolved for a few months.
cobra10363
Jul 23, 2024 04:13 PM
02tljj
May 2, 2019 08:56 AM
heyitsvic
Sep 4, 2015 09:38 AM
