need help with headlights plz
Old Jan 30, 2008 | 11:35 PM
aznriceball's Avatar
does anyone have an guide on how to take out the headlights and readjust them, b/c they are uneven
any help will be appreciated plz
Old Jan 30, 2008 | 11:41 PM
jaehshim's Avatar
uneven meaning what specifically?
the HID projection is uneven or the headlight structure is physically uneven?
if HID projection is slightly uneven, it is normal. one side should be a bit higher than the other.
If you need to adjust the height of projection, read manual, when you pop up the hood, there's a little hole on top of HID assembly. you can simply use a screw driver to turn right or left to change the height of the beam.
taking out the headlight assembly requires taking out the bumper, which you can also easily do. just check couple threads via search.
Old Jan 30, 2008 | 11:46 PM
uneven as the right side project farther then the left one
Old Jan 31, 2008 | 12:32 AM
Bennnnn's Avatar
if you mean farther as it is a bit higher, it is like that so you don't blind traffic on the other side.
Old Jan 31, 2008 | 12:35 AM
mclovintsx's Avatar
you can provide us some pics so we can judge whether or not if its displaced.
Old Jan 31, 2008 | 12:57 AM
dank2hydro's Avatar
it should look like this
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
