need help with headlights plz
uneven meaning what specifically?
the HID projection is uneven or the headlight structure is physically uneven?
if HID projection is slightly uneven, it is normal. one side should be a bit higher than the other.
If you need to adjust the height of projection, read manual, when you pop up the hood, there's a little hole on top of HID assembly. you can simply use a screw driver to turn right or left to change the height of the beam.
taking out the headlight assembly requires taking out the bumper, which you can also easily do. just check couple threads via search.
AmplifiedDetails
Sep 24, 2015 02:55 PM
