Need help - few car problems!
Old May 15, 2016 | 04:16 PM
swttsx007's Avatar
Hello!
I have an 07 TSX with 121k miles on it. My car has developed a severe "shake" and pulsation in the brake pedal when braking from higher speeds. The "shake" is in the steering wheel." I'm guessing just warped rotors (getting new pads/rotors in 2 weeks)
Another issue I'm having is the buttons on the right side of the steering wheel. The button that scrolls through the different "screens" "options" (MPG, Tire pressure, etc. is not working when you press it. The one below it still works that allows me to look at the temperature, reset the oil life, etc. Is this fixable, and what does this part cost? Does anyone have a part #? How hard of a fix is this?
I would REALLY appreciate some help!
Old May 17, 2016 | 02:23 PM
gogozy's Avatar
commming from experiences of 2004 TSX and other honda/acura , the problem of #1 is likely the brake components, often rotor. if you live in area where road salt are common in winter, try clean and lubricate the pin once a year.
sorry can't help #2 as these function are post 2004 build
good luck!
00TL-P3.2
Feb 11, 2019 11:23 AM
nore03
May 4, 2016 02:10 PM
Evilocity
Apr 22, 2016 09:33 AM
