need help!! with brake installation.
Old Apr 21, 2007 | 08:09 PM
daicacharco's Avatar
hey, alrights
i got the new brake pads in place but the thing that presses the brake pads together is upwards.
here is my problem
as you can see the circled piece. that piece wont let me put back down the brake shoes ...
Old Apr 21, 2007 | 10:58 PM
theone55699's Avatar
u need a C CLAMP.
u need a C CLAMP to push is back in.
Old Apr 21, 2007 | 11:24 PM
how many inch of a c-clamp ?
Old Apr 21, 2007 | 11:30 PM
Old Apr 22, 2007 | 12:29 AM
joerockt's Avatar
Just dial 1911
You just need something like this:
Any auto parts store will have it. Its called a brake piston tool.
Just make sure to watch your brake fluid level when you push the piston back. Dont let it over flow.
Old Apr 22, 2007 | 01:08 AM
JTso's Avatar
You would use the tool above with the "old" brake pad to push the piston back in. The old brake pad is used to protect the piston and provide leverage. Also watch the piston seal and make sure it's not damaged by mistake.
Old Apr 22, 2007 | 01:14 AM
Old Apr 22, 2007 | 01:15 AM
is that the brake pad clampped by the toool?
Old Apr 22, 2007 | 07:49 AM
moda_way's Avatar
As JTso said, you will use one of the old pads and this tool to press the caliper piston back in. 2 hints, use a little lube (WD40 or lithum grease) around the boot and caliper piston before you press it back in. This way if the boot won't rip from age/heat if it should bind a little. The piston is pushed straight back in.
Just a heads up, there are totally different instructions and tools for doing the rear brake pads.
Old Apr 22, 2007 | 10:59 AM
mg7726's Avatar
She said: it's GINORMOUS!
in addition, using the car spare jack for brake work (or any work for that matter) is a NO-NO. spend the $30 on a real jack.
Old Apr 22, 2007 | 11:54 AM
joerockt's Avatar
Just dial 1911
Here's a way to do it with a c-clamp if you dont want to buy the tool.
Old Apr 22, 2007 | 12:52 PM
moda_way's Avatar
^^Pic no workie for me
Old Apr 22, 2007 | 01:41 PM
JTso's Avatar
The pic did work earlier. I think the site is down.
Old Apr 22, 2007 | 01:48 PM
SoCaliTrojan's Avatar
Let me help you!
bah, now i know i have to spend some money when my brakes wear down. On my accord, the piston had a slot that I could use a screw driver to twist it back in.
joerockt, the site for the pic you posted an hour ago is down....did you have the picture or site saved? Or can you describe what it is?
Old Apr 22, 2007 | 03:52 PM
joerockt's Avatar
Just dial 1911
Pic works for me
Its just a pic of a C-clamp (6" I think?) on the caliper pushing the piston back in with the pad.
Old Apr 22, 2007 | 05:16 PM
got it ;]
Old Apr 22, 2007 | 05:45 PM
dolparism's Avatar
chanellock is much easier....for me.....
Old Apr 22, 2007 | 07:03 PM
moda_way's Avatar
The rears could technically be screwed in. The fronts are always a push in.
Old Apr 22, 2007 | 07:35 PM
jlukja's Avatar
Pic works for me
The pic must still be in your cache. Its not working for me either.
Old Apr 22, 2007 | 07:52 PM
JTso's Avatar
Not the same picture but you get the idea.
http://images.google.com/images?hl=e...mp+brake&gbv=2
Old Apr 23, 2007 | 06:45 AM
LoveMyTL-S's Avatar
For the rear brakes, I used a special tool that allows you to use a socket wrench to screw the piston back in. BTW, pic above is working.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
