Need help with alternator replacement
TXSTATE BOBCATS
Trying to replace the alternator. I have everything disconnected and ready to pull the old unit out except for the two bottom bolts. How do I get to these bolts? There seems like there is no room to get a ratchet there especially with all the ac hoses and radiator fan in the way. I have attached a pic to show you which two bolts I'm talking about. They are the bottom 2 of the 3 pointed at.
![](http://img545.imageshack.us/img545/8416/captureymh.jpg)
Uploaded with ImageShack.us
I used a long box wrench I believe it was a 13or 14mm but the wrench was 8-12 inches long it was helpful to get the longer one or use a regular sized one and maybe some sort of cheater bar to help get the pry you need to loosen the bolts....
chrisr
12-04-2015 02:17 AM
