NAVIGATION PROBLEM!!! Please Help!!!
Old Nov 19, 2008 | 01:24 AM
Joeyme825's Avatar
I have a 2004 TSX w/ navi system. I have had some problems with the voice over on the GPS. Then on the way back from austin the GPS system just gave out. It kept restarting over and over. Then it would work for 5 minutes. then it would restart. now all it does is ask me to put in a code. What should i do? should i buy a new disk? is the disc scratched? Any help would be very much appreciated.
Old Dec 12, 2008 | 08:18 PM
mars's Avatar
First thing you need to check is whether the problem is with the Disk or with the Drive,,
1) Pop out the disk and clean it and insert
2) Popout the disk burn an image and insert the Disk and see what happens..
If you still get the same message run the diagnostics..
Hold Map/Guide+Menu+Cancel for a few seconds you will see the diagnostics screen..
Refer to the thread..
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/dvd-disc-reading-error-3g-garage-i-001-a-690561/
Don't change any thing in the srcreen..
I had the issue that was mentioned in the above thread and i have sent my Drive to Alpine and they repaired it now everything is working fine..
When i took to it to the Dealer before sending it to Alpine, they wanted $200/- to just check what's the problem..
Alpine repaired everything for 150/-
mars
BoricuaTL
Apr 8, 2016 01:08 PM
tallyrlx
3G RLX Audio, Bluetooth, Electronics & Navigation
Feb 26, 2016 03:44 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
Gianni Formica
Sep 7, 2015 08:28 PM
travr6
Sep 6, 2015 02:11 PM
