Navigation Help - "Check Disk" Error
Old Aug 15, 2010 | 01:09 PM
thatflyingpan's Avatar
5th Gear
Hey guys, I recently tried to run a back-up copy of my navigation disk, but it did not work after trying to load. So, I gave up and decided to use the OEM nav disk, but am now getting a "Check Disk" error everytime after it attemts to download software . Is there anyway to reset the navigation system or fix it?
Someone suggested that I hold down the Menu, Map/Guide/ and Cancel buttons, but nothing comes up.
Any help is appreciated. Thanks.
Old Aug 15, 2010 | 08:00 PM
Jimmy The Saint's Avatar
well with the OEM DVD you need to force a download.
so remove the ground to the battery for 30 seconds with the origional DVD in the car. The old OS will load back after you start the car up
Old Aug 20, 2010 | 03:59 AM
Rocket_man's Avatar
Summer is Coming
you can't copy the disc...... long story. if the power cycle via the battery doesn't work, you may have gotten some dirt in the DVD player. Try to clean the laser head and disc.
Old Aug 20, 2010 | 10:07 AM
you can burn any DVDs before 4.61 i believe or at least I did. You just have to know what you are doing
Old Sep 4, 2010 | 02:09 PM
crazyaccord's Avatar
just call alpine, they can fix your dvd unit for under 200 bucks. Here is the number 800-421-2284
tallyrlx
3G RLX Audio, Bluetooth, Electronics & Navigation
Feb 26, 2016 03:44 PM
Big mo
4G TL Problems & Fixes
Sep 12, 2015 07:22 AM
Gianni Formica
Sep 7, 2015 08:28 PM
travr6
Sep 6, 2015 02:11 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
