my rear alignment is out of spec without drop.
Old Sep 25, 2006 | 01:24 AM
Newcleannow's Avatar
my car is stock actually with new wheels and tires. i went to the alignment shop few days ago with four old wheels wrapped around with tires in my backseat and the trunk. during the alignment, the rear camber was out by far. the display of the rear camper was all red except one green color. he said the car need to get fixed. i didn't do anything.
can the heavy weight(over 200 lbs) on the back portion of the car cause the problem during the alignment? i never felt any problem of drifting to one side on my car.
should i get check again without the heavy weight? can it get fixed?
Old Sep 25, 2006 | 03:29 AM
aaronng's Avatar
Driver/Detailer
Yes, if your ride height is reduced because of weight, it can increase rear camber.
If it is only on one side, then it might be eligible for the rear camber tsb.
Old Sep 25, 2006 | 06:30 AM
miner's Avatar
There is a TSB out about rear alignment issues due to a badly designed rear upper arm. I had mine replaced and got a free alignment too. This was fdeon with 60000 miles on the car.
Old Sep 25, 2006 | 09:19 AM
jlukja's Avatar
Check out the FAQ section for the TSB.
james357
Feb 13, 2016 02:37 PM
Dunnik
Sep 15, 2015 11:52 PM
Sep 14, 2015 10:09 PM
obsessedmotors
Sep 10, 2015 10:49 AM
