Maintenance Required?
damn, i did EXACTLY what the manual told me:
1. Press reset and hold reset
2. Turn key to ON (II)
3. Wait 10 sec until the light resets.
Did this several times, but it never reset! Anyone have that same pb?
Looking at the '15 TLX
Otherwise you appear to be doing it correctly.
Lies!
Ok, I have an '05 TSX, and like everyone else my MAINT REQ'D light came on around 8000 miles. I have tried holding down the trip reset button, turning the ignition on (i tried both to just acc power and starting the car) and waiting about 10 seconds.
No dice. Still flashes when I start the car. Am I doing something wrong? Has anyone successfully reset this warning light?
Thanks!
Thanks!
Single Sailor
Thanks!
Thanks!
Originally Posted by SilverSting
I press and hold the reset button, turn the key to on (pos II)... and after ten seconds the temperature gauge starts adjusting itself and the reset light stays on!
Hold the botton down, then turn the key to on and wait approx 30 seconds to be sure. My temp started adjusting also (I had to readjust the temp when I was done, apparently you can set it to display up to +5 or -5 degrees from the reading). The "key" is to hold the button down for a good 30 seconds. That worked for me.
joflewbyu2
08-18-2019 10:38 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
2005, 30, acura, gauge, light, maintenace, maintenance, mdx, playdoh, required, reset, sec, stays, temperature, tsx
