Lower Ball Joint Help, Castle nut spins with it.
Old Jul 16, 2011 | 04:57 PM
azndoritos209's Avatar
I had recently changed my axle and ran into some problems putting things back together. When i was trying to separate the LBJ from the lower arm i used a pickle fork which ripped the boots. Im now trying to bolt the castle nut back on but it still spins with the ball joint. What can i do to stop it from spinning so i can tighten it? should i replace with the boots on the ball joint?
Old Jul 16, 2011 | 07:53 PM
Heres some pics of the joint and boot removed.
Old Jul 18, 2011 | 04:20 AM
nbtx's Avatar
still plays with cars
Replace the ball joint - it must have an intact seal.
Old Jul 18, 2011 | 11:41 AM
I cant just replace the boot?
Old Jul 18, 2011 | 11:44 AM
ton8383's Avatar
only way it itll do that is if the castle nut isnt on right or the threads are shot replace the ball joint ive done a hundred of these and that is what i can tell you
cycdaniel
Dec 17, 2019 10:58 AM
jblessing
Aug 8, 2018 09:43 PM
marcelft
Jul 10, 2018 06:17 PM
jblessing
Wash & Wax
Sep 17, 2015 09:28 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
