Low Oil Level
Old Dec 22, 2004 | 01:12 PM
thenation's Avatar
Low Oil Level
I purchased my TSX in September, and i had to add 8 litres of oil since....i know during break in the car eats oil but 8 litres worth......i took my car in yesterday to get it checked out, i have 6600 kms on it and 1 hour later they said its ready and that the oil level was pretty low....they did a complete service on it..i was life WTF, i came to get my car checked not serviced...they said in order for us to check the oil consumstion they needed to do an oil change and also they did a complete service......also i will need to bring the car back after 1000kms so they can check it again....what do u guys think?
Old Dec 22, 2004 | 01:22 PM
Powered by Honda's Avatar
Strange....
Old Dec 22, 2004 | 01:25 PM
Viking's Avatar
Quattro in.....
If you didn't authorize them to perform those services you shouldn't have to pay or they should give you your next oil and filter change free of charge.
Adding 8 liters of oil since September is a little excessive. Did they say what caused it?
Old Dec 22, 2004 | 01:30 PM
thenation's Avatar
they said that they don't know what caused it and that i will need to bring in the car in 1000kms time to have it checked...they have no clue....
Old Dec 22, 2004 | 01:44 PM
kurt_bradley's Avatar
If it were my service department (which it isn't in this case), I would make sure that the customer authorizes work before it is performed (required by law in order to require payment in this state), check the PCV valve. If that was fine (which I'd guess it would be in your case), I'd have to start checking the lines. You've got to have a leak somewhere or a blown head gasket. Then again...that would leak oil everywhere if that were the case.
Old Dec 22, 2004 | 01:45 PM
majormojo's Avatar
such a dirty birdy
8L of oil!!?? Holy crap! Mine (and many others) required an addition of about 1L before the first oil change, but that amount is crazy. That's more than the entire crankcase capacity. It has to be going somewhere. Either a leak, or it's being burned. Have you looked for a leak under the car? Check around the front & rear seals and the oil filter. Do you ever see blue smoke from your exhaust? Check your spark plugs, are they oil-fouled?
Old Dec 22, 2004 | 02:58 PM
jwb998's Avatar
My mom bought a new Probe in 1993 that had a similar problem. It ate oil all the time. I worked at the garage where she bought it. I would take it to work for them to look at. By 5000 miles, the exhaust pipe was black with sot. They eventually pulled the engine and replaced the block. The original block had jagged holes in two of the cylinders walls that I could stick my little finger through! I don't remember the car smoking, but it was 12 years ago.
Old Dec 22, 2004 | 04:26 PM
Dude, you're talking about a Ford, though.
Old Dec 22, 2004 | 04:32 PM
gsclifton's Avatar
ABP TSX
LMFAO
Old Dec 22, 2004 | 11:56 PM
TSXsurf's Avatar
NBP/EBONY/6MT
Make sure you're writing down and keeping track of all of this info - receipts, etc too. Its definitely a problem if you've used 8L of oil.
Old Dec 23, 2004 | 04:51 AM
sauceman's Avatar
Moderator Alumnus
Old Dec 23, 2004 | 05:00 AM
biker's Avatar
Something is very wrong with any car using 8L of oil in that short a period.
Old Dec 23, 2004 | 11:45 AM
thenation's Avatar
dealer inspected it....i inspected there are no leaks...what could it be......i'm just pissed....
Old Dec 23, 2004 | 12:48 PM
nuke's Avatar
Nuke
any chance of somebody playing a "joke" on you and draining off some of the oil from time to time?
Old Dec 23, 2004 | 01:55 PM
Viking's Avatar
Quattro in.....
Does the car's exhaust smoke excessively?
Old Dec 23, 2004 | 02:35 PM
thenation's Avatar
no it doesn't
Old Dec 23, 2004 | 07:29 PM
danotto's Avatar
My RSX had this problem, along with most of the early RSX's. Sounds like the dealer is doing the right thing with the oil consumption test. Standard procedure is to do an oil change and then keep track of the oil consumption. Let the dealer add any oil that might be needed so they can keep track of it. I forget what Honda/Acura says is unacceptable consumption, something like a quart every 1000 miles. They will replace your engine if they find the problem bad enough
MY TSX is another story however. It has not burned a drop of oil in the first 4000 miles.
Old Dec 24, 2004 | 02:01 PM
thenation's Avatar
Can i request a new TSX if this continues?
Lemon Law? does it apply in Vancouver, BC
Old Dec 27, 2004 | 03:16 PM
thenation's Avatar
bump......
Old Dec 27, 2004 | 07:37 PM
thenation's Avatar
i washed my car today.....and also checked the oil level and guess what its below the second circle.....WTF is going on...the oil isn't leaking.............i just got a oil change last tuesday and since then only put 300 kms on it......i will be going to the dealer tomorrow
Old Dec 27, 2004 | 08:57 PM
stuckthrotle's Avatar
when u start it up is there alot a blue smoke? Is there an oil smell in the exhaust?
Old Dec 28, 2004 | 10:17 AM
thenation's Avatar
no blue smoke and no oil smell
Old Mar 12, 2007 | 09:24 PM
Tsx6363's Avatar
check your exhaust for residue of burnt oil, around the rim of the exhaust and your bumper
Old Mar 13, 2007 | 06:22 AM
rb1's Avatar
rb1
It's either burning or leaking (either onto the ground or into the cooling system, but presumably they checked that also).
I had a problem like this in an old Toyota Corolla - most of the oil was running out while the car was running, but it would leave a drop or two on the ground after stopping the car. I ended up replacing the wrong part (oil pan gasket -- major beeyotch) before the correct part was determined. It was an oil pressure switch, about $8 and 5 minutes of labor.
One thought - find a clean spot of pavement and let your car idle over it for 10-15 minutes, then see if there is any oil under the car.
I don't know what the Canadian warranty is, but in the U.S. it's very good. Your dealer is now aware of the problem and has done the right thing to "benchmark" the problem. From this point, just have things checked regularly and documented.
If they can't find the problem, I would think they would have to do something major (e.g. new engine, or maybe buy the car back from you), but the key to this is being careful to build the case. Keep a log of dates and amounts of oil added, all receipts, etc.
Old Mar 13, 2007 | 07:06 AM
curls's Avatar
Someone stole "My Garage"
This thread was 2 1/2 years old... (Thank goodness you replied first, and not me... like I was planning to... LOL!)
For future reference, here's my similar story: https://acurazine.com/forums/showthread.php?t=28541
Old Mar 13, 2007 | 09:28 AM
jlukja's Avatar
I was like
Old Mar 13, 2007 | 12:05 PM
rb1's Avatar
rb1
Originally Posted by jlukja
I was like
Dammit! I keep getting sucked into these old threads that someone else wakes up. I'm going to have to check the dates more closely.
Feb 25, 2020 09:57 AM
Aug 15, 2019 12:58 PM
merc009
Jan 27, 2016 10:34 AM
thegipper
Oct 21, 2015 07:19 AM
robm
Sep 18, 2015 07:53 AM
