Lip Spoiler Adheasion Question
Old Jul 21, 2005 | 04:25 PM
Zasker1's Avatar
Polar Chicken
For those of you that have installed the screw less lip spoiler, did you have any adhesion problems. I put mine on about a week ago and noticed that its starting to peel off of my trunk. While it is possible that I have an adhesion problem I think the main issue is that the BMWE3 trunk is flat while the TSX has a slight vertical curvature to it, thus the ends are peeling. While I could go the route of inserting screws into the corners I was wondering if anyone know of a good adhesive I could squirt under there with a syringe.
Has anyone else had this type of issue?
Ideas?
Left Side
Right Side
Old Jul 21, 2005 | 04:41 PM
tsxgirl's Avatar
6th Gear
You could it with a stick.....or I could just sit on the trunk and hold it down.....
But that might scratch the paint........
Post a Picture of your CAR!!!
Thats just my
TTFN - TIG
Old Jul 21, 2005 | 05:06 PM
Zasker1's Avatar
Polar Chicken
You must be blonde as there are two links in that post "Left Side" and "Right Side"
Old Jul 21, 2005 | 05:10 PM
TSX.Fury's Avatar
send me a link to JDM??
hmmm did you clean it before putting it on? (you should clean the area you are gonna put it on with alchohol before sticking it on) I would say carefully take it off the same way people debadge (dental flows and goo gone) and buy some 3m and stick it back on. Personally I wouldn't try drilling any holes.
Old Jul 21, 2005 | 05:12 PM
Zasker1's Avatar
Polar Chicken
Oh forgot that part of the thread, I cleaned it with alchohol before and used a 3m Prep sponge that has Xylon on it to soften the paint, I put it on the 3m strip and the trunk. The local body shop stated taht this is all that should be needed. its still sticky there but I need something alittle stronger.
Old Jul 21, 2005 | 05:19 PM
CarbonGray Earl's Avatar
Dude, I all I have to say is....you are in Phoenix. The heat could be your problem.....The heat kills people, maybe it kills adhesive?
I used to live there, I know what its like there at this time of year. Any form of plastic, glue, etc, becomes very pliable this time of year, especially if its left out in the sun like your spoiler might be.
Old Jul 21, 2005 | 07:00 PM
drigo's Avatar
i preped mine by sanding the bottom first then clean with alcohol...also wiped trunk surface with alcohol...applied 3m then installed it on the trunk..applied some pressure all over several times...its on there very good..i couldnt pry it off if i wanted to...iv'e had it on for a little over a year and i live in florida...it gets over 100f with the heat index alot...so i dont think the heat was the factor...i'm guessing your problem was from the prepping and applying...my advice would be to redo it..dont screw it on....!!!
Old Jul 26, 2005 | 03:20 PM
pcdawg's Avatar
Its a known problem for it to come off....
I had to re-do mine as the ends was coming off a little bit....with our cars we have to slightly curve it and stick it on...after some time it'll come off ... dont worry about it unless it really bugs you. Severe heat (esp in Phoenix ) and cold (where it can be in Toronto) the tape will not adhere and come off...
Old Jul 26, 2005 | 05:32 PM
kyotousa's Avatar
how do you use take them off?
i didn't clean it with alcohol.......but i did wash the car before i apply the tape XD
Old Jul 27, 2005 | 02:05 AM
Kazzaf's Avatar
use crazy glue
Old Jul 27, 2005 | 09:25 AM
jerzpwr's Avatar
My friend iamhomin has the same problem but only on the left side. About six inches of the spoiler is coming off. He used 3M double sided tape to put it on his trunk.
Old Jul 27, 2005 | 09:35 AM
dontcare4urshyt's Avatar
theres a glue promoter that 3M makes. I never had a problem with my lip spoiler to need it. but I did a customers car with carbon fiber accents on the interior and used the promoter to make the double sided tape stick to sharp curves. worked like a charm.
Old Aug 2, 2005 | 08:02 PM
scheißterhöffer's Avatar
Where did you get this glue promoter? I've checked Advance Auto Parts, WalMart, Meijer, Lowes, and Home Depot, and no one has it.
Thanks.
Old Aug 3, 2005 | 02:34 PM
Zasker1's Avatar
Polar Chicken
I got my glue promoter from a paint shop, realy all it is, is some xylon, that softents the clear coat for a better adheason.
BoricuaTL
Apr 8, 2016 01:08 PM
mugen_kid
Nov 13, 2015 10:38 PM
Sep 17, 2015 08:57 PM
datadr
Sep 12, 2015 09:12 PM
spoiler900
5G TLX Photograph Gallery
Sep 11, 2015 09:39 PM
