Lightsss !!!
Old Aug 28, 2007 | 07:09 AM
rhyn618's Avatar
9th Gear
Lightsss !!!
HI
I own a 2005 tsx and I noticed something yesterday but didn't know if it was
normal or not. Is the window lock button suppose to light up in the dark ??
all the buttons lighted up except for that button !
and also am I suppose to be able to turn the lights (two of them located close to
the sunglass storage) while driving ?
I tried to turn it on while driving but I couldn't get it to work.
when I open the car door then it will turn on.
thanks !!
Old Aug 29, 2007 | 11:36 AM
gftgrill's Avatar
you should be able to turn the map lights on while driving. you just push it in.
Old Aug 29, 2007 | 11:38 AM
BackToStock's Avatar
Finding my TL-S
hmm yes, you should be able to turn on the lights at anytime, even when the keys arent in the ignition.
Old Aug 29, 2007 | 12:16 PM
DLTSX6MT's Avatar
The window override button does not light up. If you look closely at it, you can see that the graphics are painted onto it, whereas on the other buttons you are looking at bare white plastic where the lighting underneath shines through. IIRC, the heated mirror button doesn't light up, either (although there is an indicator light that lights up after you push the button).
astridnunez123
Nov 13, 2010 01:28 AM
