Just got my first oil change on my 06, now how do I reset the Maintenance Minder?
I would have thought once the oil was changed, it would stop telling me I need to change my oil, but oddly enough it doesn't. I skimmed through the manual and couldn't find the answer. I'm almost wondering if they really did change my oil... Anyways, I was hoping someone might give me a quick answer. Thanks
mmmmmm....
I dont know anything about 06 guage but you could try to resetting it by disconnecting the battery (make sure to have your radio code). You can also try this....put your key in and turn it to II and press down the two knob on the guage for 10 sec and it should reset it.
good luck,
edit: I doubt it....Acura isn't small store on the conner. They aren't going to do stupid thing like to get into major trouble..
good luck,
I'll try that advice, thanks for the reply. I still have a hard time believing that it doesnt automatically reset though. I mean it tells you when you need to change your oil supposedly but yet it doesn't know when and cant tell the difference when you have fresh clean new oil in there?? FWIW I had my oil changed at a local auto shop and not through Acura.
mmmmmm....
mmmmmm....
You shouldn't take your car to local shop to gett oil change. I heard of plent of nasty stories about how bad they are... I first recommend doing it yourself but dont got time for it then hit the acura or honda dealer to get it done. It only cost $29.95 with tax. Don't get fool by the price of local shop...
mrgold35
Check this thread out from about a month ago:
https://acurazine.com/forums/showthr...ght=life+reset
You shouldn’t have to disconnect the battery after every oil change. Disconnecting the battery every 3-5,000 miles might or might not cause problems with other electrical systems down the road.
Reposted from the other thread:
Originally Posted by PWPTSX
2006 Owner's Manual, on Page 269 said:
1) Turn the ignition switch to the ON (II) position.
2) if the engin oil life display is not displayed, press the SEL/RESET button on the steering wheel repeatedly until it comes back.
3) Press and hold the SEL/RESET button on the steering wheel for more than 10 seconds. The remaining engine oil life reset mode will be shown on the MID.
* To reset the engin oil life, press the INFO button on the steering wheel to select "RESET" on the display, and press the SEL/RESET button.
mada51589
05-03-2022 08:54 PM
Zonian22
11-14-2015 01:20 PM
HydrasunGQ
09-14-2015 10:14 PM
Zonian22
09-02-2015 08:19 AM
