Jangling Chain & Metal Grinding
Old May 31, 2006 | 11:20 AM
mssully's Avatar
Unhappy Jangling Chain & Metal Grinding
My 05 AT TSX has 25K miles and has developed a problem the dealer cannot seem to duplicate. Jangling chain sound which last about 20-30 seconds and then turns into a metal grinding, usually between 20-40 mph. This also seems to occur when the outside temperature is over 90 degrees. Same thing happened last summer when the temperature got extremely hot but not sure if that is contributing). Another clue is that it only occurs when the car is moving( forward or reverse doesn't seem to matter). When they towed the car to the dealer he said he cannot get the car to make any noise. Any info re this type of problem is very much appreciated. I love my TSX but have lost faith in making a long daily commute.
Old May 31, 2006 | 11:58 AM
joerockt's Avatar
Just dial 1911
How often does it happen? You need to tell the dealer to have a tech ride along with you so you can point out the sound to them.
Old May 31, 2006 | 01:08 PM
curls's Avatar
Someone stole "My Garage"
joerockt -- LMFAO @ your avatar.
mssully: Could it be the A/C, possibly? Try turning AC off next time you hear the sound and see if it stops immediately. Also, as joerockt mentioned, get a tech to ride w/ you to pinpoint the sound. Sounds like some kinda resonance causing the noise.
Jul 16, 2017 07:33 AM
AJRozsa
Oct 5, 2015 07:50 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
AcuraKidd
Sep 26, 2015 04:10 PM
