Rear Camber TSB
Old Mar 17, 2006 | 02:26 PM
cl7tsx's Avatar
JOATMON
Exclamation Rear Camber TSB
Hey guys,
There has been some discussion regarding rear camber issues on the TSX (specifically, it being out of spec). I thought I would pass along this info.
I just learned that Acura released TSB 06-007 on March 8, 2006 addressing the right rear camber being out of spec on the TSX. Affected models include all 04s and a range of 05s. As I understand it, the solution involves replacing the right rear upper arm and a four wheel alignment.
Mods: I apologize if this is a repost.
Old Mar 17, 2006 | 03:00 PM
moda_way's Avatar
I don't see that being on AllData yet, but no telling when the system updates. I'll check again since it has only been issued for 9 days.
Old Mar 17, 2006 | 04:48 PM
TSX2345's Avatar
A DiRTBAG decal on my
Hmm So should I hold off on my shocks + spring install until I take my car in for this or do it regardless?
I am thinking do it and take it to dealer for a free alignment?
Old Mar 17, 2006 | 04:52 PM
gsclifton's Avatar
ABP TSX
You will not get a free alignment after a shock or spring install.
Old Mar 17, 2006 | 04:53 PM
JoeC1982's Avatar
does this apply if you have spc camber kits already?
Old Mar 17, 2006 | 05:01 PM
TSX2345's Avatar
In the Post #1 says "...the solution involves replacing the right rear upper arm and a four wheel alignment...."
If they do replace the part won't it require an alignment regardless?
Old Mar 17, 2006 | 05:43 PM
gsclifton's Avatar
ABP TSX
If you put aftermarket parts on the suspension to lower it down, the dealer is not going to give you a free alignment. However, I see your point in the TSB. You might be lucky and get away with it. I just see dealers saying, you lowered it so you deal with the camber issues now.
That might be a grey area with the dealer.
Old Mar 17, 2006 | 06:32 PM
curls's Avatar
Someone stole "My Garage"
Can anyone tell me if TSB's are applicable to cars w/ mileage above the bumper-to-bumper warranty? I have 90K+ km's (bumper to bumper up at 60K km's). Will this apply, and does the dealer HAVE to do it or is it "if they feel it needs it" ?
Debating on doing this before the Comptech RSB goes on in a month, just so they don't bitch about it.
Old Mar 17, 2006 | 06:44 PM
TSX2345's Avatar
Hmmmm perhaps I should wait....
Old Mar 17, 2006 | 07:40 PM
LannyM's Avatar
Hondaholic
From an Acura policy standpoint, at least according to my dealer, the TSB for this states you must be within warranty mileage.
Old Mar 17, 2006 | 08:19 PM
moda_way's Avatar
Or at the service managers discretion.
Old Mar 19, 2006 | 05:26 PM
danotto's Avatar
Is this TSB a fix for the drifting to the right on crowned roads?
Old Mar 19, 2006 | 05:29 PM
Alin10123's Avatar
Hmm... moda_way seems to know a lot of info on Acura stuff.
Do you work for a dealer???
Old Mar 19, 2006 | 05:32 PM
danotto's Avatar
Correction: My post above should say "drifting to the LEFT"
Old Mar 19, 2006 | 05:44 PM
moda_way's Avatar
Nope... I work for an aircraft engines maker, but I play an Acura employee on T.V.
I have access to a lot of Honda/Acura stuff.
Old Mar 19, 2006 | 05:46 PM
moda_way's Avatar
I'm still not seeing the TSB posted in AllData yet. Once I do, I'll copy it here.
Old Mar 19, 2006 | 07:35 PM
Alin10123's Avatar
Aircraft engines? Lycoming? Rolls Royce? GE? Continental?
That's awesome!
Old Mar 19, 2006 | 07:52 PM
ckiggins314's Avatar
http://www.alldata.com/tsb/Acura/index-post.html
Last TSB at the bottom.
Old Mar 19, 2006 | 08:17 PM
RMATIC09's Avatar
How do i know if i have this problem. Mkay.
Old Mar 19, 2006 | 08:20 PM
str8 tsx's Avatar
I have a '05 model, does that mean if I take it to the dealership and mention this, they will fix it under warranty?
Old Mar 19, 2006 | 08:29 PM
afici0nad0's Avatar
compare the vin range on the tsb and with your car. if your car is within the vin range, you should be ok.
if your car is not within the vin range, i'm not sure what would happen.
btw, the alldata index for the tsx is very informative. thanks. i used to check alldata, but it would only allow me to view the problem description, nothing more...
Old Mar 19, 2006 | 08:35 PM
afici0nad0's Avatar
"you should be ok." = "you should be able to take it to the dealer for the warranty work w/o hassle."
Old Mar 19, 2006 | 08:39 PM
The majority of the TSBs listed are for the MDX and the TL. Looks like those two vehicles have numerous problems!
Old Mar 19, 2006 | 08:46 PM
afici0nad0's Avatar
ya, i noticed that too...
str8 tsx's Avatar
Is there a general website that I can refer to for a list of all TSB's for the TSX? Thanks!
Old Mar 19, 2006 | 08:48 PM
savage's Avatar
Engineer
all 2004's huh...
Old Mar 19, 2006 | 09:36 PM
waTSX's Avatar
Have camera, will travel
Dude, your car's drifting on crowned roads because the road is slanted.
Old Mar 19, 2006 | 09:47 PM
danotto's Avatar
Partially true, but my girlfriend's 06 VW Jetta barely veers left on any road. My 350Z did not drift NEARLY as much. Crowned roads will cause drift, but I have never had a car drift like the TSX. I'll ask again, will the TSB help in this area?
BTW, I have had an alignment, but there was no fix for rear camber at the time.
Old Mar 19, 2006 | 10:16 PM
batboyvaj's Avatar
remember...this is just a tsb. not a recall. if your tsx is not out of spec, they will not replace or fix anything
Old Mar 20, 2006 | 04:39 AM
925tsx's Avatar
B A N N E D
whats stopping them from saying, oh yea, your in spec, when in reality your not?
are there symptoms you would notice?
Old Mar 20, 2006 | 06:27 AM
moda_way's Avatar
An alignment report. Every shop has the ability to give one and they can't edit the measurements.
Old Mar 20, 2006 | 06:31 AM
moda_way's Avatar
Originally Posted by ckiggins314
Found it finally. Thanks for the link. I had to do some searching b/c it wasnt' under the "All TSBs" for the 2004 TSX.
Old Mar 20, 2006 | 03:54 PM
supraken's Avatar
Try this link too.... it's not as up-to-date but has a pretty complete list of the TSB's issued, I think...
Old Mar 21, 2006 | 06:48 AM
LoveMyTL-S's Avatar
It wouldn't hurt to have your dealership check it. Perhaps during your next visit. That reminds me, I need to call them about the light in my right seat heater button. It burned out. BTW, thanks for posting this TSB.........
Old Mar 30, 2006 | 03:08 PM
nnh768's Avatar
So if i have the a-spec suspension on that i installed myself, and take it to acura to fix this problem and get an alignment, would they give me a hard time?
I installed the a-spec kit but never got an alignment because i had to go back to college and nobody was going to drive it until i got back.
Old Mar 30, 2006 | 03:13 PM
jlukja's Avatar
How did I miss this thread?
Nice link, didn't know something like this existed.
Old Mar 30, 2006 | 03:27 PM
And from a noob, too.
Old Mar 30, 2006 | 03:33 PM
jlukja's Avatar
Rep points for you.
Old Mar 30, 2006 | 07:20 PM
Stokeless_TSX's Avatar
Stokeless
hmm
Old Mar 30, 2006 | 07:32 PM
nnh768's Avatar
Anybody got an opinion on this? Also does anyone know where i can buy the service manual for cheaper than $69.00?
