Ignition noise from column
Old Dec 27, 2005 | 09:17 AM
miner's Avatar
Sometimes when I start or trun off the '04 TSX I can hear a buzzing/shocking sound as if there is a short in the ignition area on the steering column. Anyone else?
Old Dec 27, 2005 | 09:21 AM
moda_way's Avatar
Nope. Haven't heard that at all and I'm #6400 of the 03 shipped TSXs.
Old Dec 27, 2005 | 10:27 PM
Chompin's Avatar
Miner........I've heard that buzzing sound in the ignition of my 02 RSX-S. It's only happened several times and is so quick that you almost wonder if you heard it at all....but you did..:-).
Old Apr 20, 2006 | 02:30 AM
scottstsx's Avatar
7th Gear
I hear this on my '05 AT occasionally. As I turn the key I hear a buzzing sound -- like you failed to remove the funny bone in the game "Operation". It seems like its coming from the left side of the steering column or the switches on the dash to the left.
The starter cranks and the engine starts just fine.
I'm going to have the dealer take a look.
Old Apr 20, 2006 | 10:09 AM
curls's Avatar
Someone stole "My Garage"
I hear the same thing, albeit rarely. No idea what it is...
Old Nov 13, 2006 | 09:30 PM
Tumby's Avatar
Hi guys, I have the buzzing noise as well recently which it never has before. The noise comes up when making the 2nd turn where the battery starting charging and where it swith on the engine oil pumps. The same problem occurs when turning the key backward from level 2 to 1. Have any one of you ever find out the cause?
Old Feb 16, 2007 | 10:37 AM
DeeCee's Avatar
I have the same problem
I posted a topic about this problem a few days ago. I should have described the noise as a buzzing noise instead of a clicking noise. I'm guessing that it's not an issue since all of us are experiencing the same noise amongst different year TSX's. I think it has something to do with the ignition disabler (if that's what its called) and the key that we use....like it's trying to read the circuitry in the key or something. I'm kind of relieved that I'm not the only one that has noticed this noise.
Old May 14, 2007 | 10:57 PM
evenq's Avatar
I'm starting to have this same issue which just started. Its happened twice this week. Has anyone else have this problem or is this just a normal thing?
Old May 15, 2007 | 05:55 AM
Tumby's Avatar
I had this fixed already..... to mine, it was a noise from the cluster underneith of the fuel gauage. The dealer basically had replaced the entire gauage for the fact that all meters are linked by the same piece of mother board. The only problem is all millage reported on your vehicle is gone.....
Old May 15, 2007 | 07:09 PM
curls's Avatar
They should have transferred the mileage to the new odometer memory. It's a standard procedure thats in the service manual but they might have been lazy and didn't do it. Bring it back ASAP, because you COULD be charged under penalty of law for odometer fraud as it stands right now...
Old May 16, 2007 | 06:03 AM
Tumby's Avatar
I hear ya.... and I double check and triple check w/ Honda Canada..... and beside, my few friends work for Honda or in the industry.... they are claim Honda is the most stupid that cannot modified their own odometer into the original milage. What they did is put a sticker that tells the date and location of dealer where the cluster was replaced, and at what milage.... I know it sounds stupid but this is the fact.....
Old May 16, 2007 | 03:22 PM
04rob's Avatar
I've had the same buzzing noise periodicaly for the past couple years. Only happens when I'm turning on the car though. It almost sounds like the little gears that drive the tach/speedometer are slipping momentarily.
I thought for a while it only happened if I didn't quite step on the clutch pedal all the way, but it seems to be a problem with the AT's too.
Old May 16, 2007 | 05:45 PM
Tumby's Avatar
This was exactly what I had got... the prob w/ the cluster underneth the gauage.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
malvothegreat
Sep 29, 2015 12:38 AM
