Icelink plus / Steering Wheel control problem
Old Feb 20, 2006 | 04:35 PM
Nickfit's Avatar
For all you Icelink plus users out there....
Can you navigate through the Denison UI menu using steering wheel controls?
When I get to the Denison menu (CD 6), I'm able to move up and down the menu list using the steering wheel's CH + and - buttons, but not able to select (hold down "ch +" on steering wheel) or go back (hold down "ch -" on steering wheel). The head unit buttons do work.
I called the support line at Denison and they said it isn't compatible, even though it says it is in the user guide..... I don't think the support team at Denison gave a crap about my issue.
Has anyone run accross the same issue with the steering wheel control/Denison UI?
Aside from that gripe, i'm impressed with the performance of the unit.
I have an 05 TSX with an ipod mini.
Thanking you in advance!!!
Old Feb 20, 2006 | 05:31 PM
leftride's Avatar
i want to ride my bicycle
this belongs over here:
https://acurazine.com/forums/audio-video-electronics-navigation-22/
but since i am here....what you are describing is the way it should work.
in order to 'select' and 'go back' you need to use the FF and RWD buttons which are NOT available on the steering wheel controls. the only way to FF and RWD is by holding down the track next/prev on the head unit. This is because of the car not because of the icelink.
Feb 25, 2020 09:57 AM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
Charlespsu
Sep 2, 2015 09:54 AM
MyKids&Cars
Sep 2, 2015 12:03 AM
