How to remove door panel? Help
Old Oct 29, 2008 | 02:39 AM
rockyrainier's Avatar
Can someone please give me the instruction to open my driverside door panel? I can't seem to find it anywhere. I'm getting alot of rattles from my door panel when playing music.
Old Nov 8, 2008 | 05:37 PM
mars's Avatar
Here they are:
A) Remove the inner handle (A). Take care not to
scratch the door Danel,
-1 Pry out on the bottom portion of the cover {B)
to releaset he clip {C)a nd tabs {D},t hen remove
the cover.
-2 Remove the screws.
-3 Pullt he inner handleo ut to releaset he hook (E).
-4 Pullthe inner handle forward and out half-wav
to releaset he hook (F).
-5 Disconnectth e inner handlec able( G)a nd
power door lock switch connector (H).
B) Lower the glass fully.
c) Remove the screws from the armrest portion and
inner handle opening.
D) Remove the switch panel (A). Take care nor ro
scratch the door panel.
-1 Pry out the front portion of the panel to release
the clips.
-2 Releaseth e hooks( B) by pullingt he panel
forward.
-3 Disconnectth e powerw indow swrtcn
connector (C).
E) Remove the mirror mount cover (see step 2 on
page 20-16).
Releaseth e clipst hat hold the door panel( A)w ith a
commerciallay vailabletr im padr emover( B),t hen
remove the door panel by pulling it upward to
releasei t from the lock knob (C)a nd door. Remove
the door panel with as little bending as possible to
avoidc reasingo r breakingi t. Detacht he harness
clip {D)from the door panel.
F) Install the door panel in the reverse order of
removal, and note these items;
. Replace any damaged clips.
. Make sure the connectors are plugged in
properly, and the cable is connected properly
. Check the window and power door lock
operations.
Feb 25, 2020 09:57 AM
BoricuaTL
Apr 8, 2016 01:08 PM
VA2000TL
Oct 2, 2015 08:26 AM
govtcheez
Oct 1, 2015 12:21 AM
CadiGTi
Sep 14, 2015 06:37 PM
