HID Issues
Not an Ashtray
HID Issues
This is from a discusion at Consumer Reports' website. I'd love to hear any comments or reactions:
I have a new 2004 TSX. When the headlights are on low beam, they cast a distinct, straight line of light that is so low it doesn't iluminate stop signs or street signs. Above this line of light, it's dark and things aren't easily distinguishable. When driving down a hill, the visible distance becomes even more pronounced, as the distance illuminated feels uncomfortably short which gives one an uneasy comfort level. I've taken the car in to be checked, and the service rep said it's within the specs. If I have the high beams on, the field of vision is comparable to other model cars. I drove another Acura TSX, and the headlights were identical to mine. Have you had any other complaints about this car or other models with this kind of headlight? Do you have any suggestions on how I might deal with this problem?
We have been doing headlight tests on vehicles and we have found the Acura's with HID (high intensity discharge) lights to be very low. I would check with another dealer to make sure the headlights are aligned properly. Ask them how they did it. There are several ways I have seen garages and dealers align headlights and only very few ways are correct. They may be able to move them up slightly for you. We have found on the Acura's that it does not take much adjustment up before they begin to get too bright for oncoming traffic and you will start to get flashed by that car passing by. As far as the line of light and darkness you are seeing, that will always be there and there is not much you can do except possibly move it up if the headlights can be moved up, but again remember you can only go so far and that line will never go away.
Not an Ashtray
Nope. I have the factory foglights (which I really like, btw). As should be the case, they are lower than the HID lights.
And, yeah, bondgrrl, I've been a LITTLE unhappy about how low the lights are as well.
i already raised mine the 2nd day i had the car. i moved he lights up about an inch from where they were originally on a flat wall at about 15 feet. on a flat road i can clearly see the lights lighting up just below the rear window of a car i am following. i have come to the conclusion that no matter if they are adjusted a little hiogh or set at stock spec they will eventually blind people if the car goes over bumps or hills. so why worry about it.
I didn't really notice it before, but the other night I was at a light and the car in the opposite direction had headlights much more intense than the car with the halogens next to it. As it drove past, it was a TSX. I really don't think it's the aim of the light, but perhaps Acura is giving you guys some really strong HIDs. It actually looked like the headlights were only a fraction less bright than a car with its high beams on.
When i hit a deer a few months ago the left HID was replace, but it is slightly "slanted. this profile can clearly be seen if i pull up to my garage door at night.
It took a while to get used to the HID's. My ex-girl had a GS400 with the auto leveling system. I sure wish Acura would implement this in there cars. If we had this... This thread would have no use. My
Originally posted by RogerPodacter
do you know how to adjust the HID lights on the other 2 axis? I know how to raise and lower the beam, but I want to also "tilt" the left one back into stock position.
Originally posted by bob shiftright
I have the Helms manual open to the "Headlight Adjustment" section (22-165) and there seems to be one, and only one, adjustment axis possible and that's controlled by the vertical adjuster wheel. Could the headlight mounting area have been damaged by the deer?
I could take it back to the body shop that did the work. But not only has it been months ago since they did the work, I really dont want to ask them to do all this work only to move a small part 2 mm.
and btw, i ordered my Helms manual a week ago from monday and still havent received it yet....how long does it take to ship?
Bass -- on a separate note, do you know how to adjust the HID lights on the other 2 axis? I know how to raise and lower the beam, but I want to also "tilt" the left one back into stock position.
It looks something like this ___----- With the lower side being the driver side HID. Just saying left side is a little confusing since we don't know which left side... looking at the nose or looking at the tail, that you mean.
If you knew this already and I am the confused one I apologize.
Originally posted by sheik28
Do you mean the driver side HID? You should notice a distinct difference in the two lines. This is done so that the driver side light has less of a chance of blinding oncoming traffic.
As a test when i pull up to my garage door, and completely block the LEFT HID, the right profile looks like this -----____. When i block the Right HID, the left profile looks like this ----____, but that entire profile is SLANTED down to the left. When the two are together they do not line up!
Let me clarify. I am aware of the distinct difference in the two lines as to not blind oncoming traffic. What the problem is the left HID is SLANTED TO THE LEFT. Another way to think of is this: the left and right HID anre now slightly off - almost like a "double" vision effect, when really the line should be sharp.
............._______ _______
______/ ______/
they come together at a point if you can see them reflect on somthing farther away.
in other words the left beam is on the left and the right on the right until about 30-40 feet away from you they will eventually pair together to look like this
.............________
______/
Originally posted by peetah
That's sounds like the only fix. This is my first car with HID, and I think it sucks. Can't see enough of the road when there is a mild include (i.e. on-ramp), and other cars flash me, cuz they think my hi-beams are on. Only cool (but useless) thing is when I drive home at night, my street is really dark, and the lights illuminate the entire street about 180 degrees.
Originally posted by Lung Fu Mo Shi
Auto-levelling won't do jack for what you're complaining about. Auto-leveling is to LOWER the lights when more weight is in the rear of the car.
...Along with xenon HID systems come leveling systems and lamp washers to keep the bright lights from blinding approaching motorists. From there, it's mere steps to the so-called adaptive front lighting systems now being developed. These systems propose shutters and lamp combinations to put light where and when it's needed most. from the article "let light be there" by Paul Sharke, Associate Editor Mechanical Engineering
Auto-levelling, as from the Lexus example given above, won't do this. I guess the only benefit is that they are aimed a bit higher since they don't need to allow margin for back end loads.
Not an Ashtray
Originally posted by darth62
I wouldn't go so far as to say the HID lights "suck" but I vaguely disappointed in how low they are.
I'm sure it could be done and would be a welcome addition, but as it stands, no car on the market has these.
your lights are supposed to be like that, the lines look like this (the dots are there to make the lines look correct)
______/ ______/
______/
______/ ______/
______/
i would think if its that far off the lense would be noticably crooked. is it possible that the bulb was inserted wrong or is there some peice behind the lense that can be turned that wasnt installed correctly?
i would try taking the whole headlight out and inspecting it to make sure its not damaged or reassembles wrong. otherwise take it to the dealer for replacement.
Thanks, i may ask my dealer to take a look on my next oil change. however i might have to pay unless i take it to the body shop who did the work - which i really dont want to deal with.
the lights are useable, and it really bothers me more than not functioning properly.
My lights are fine and I do see everything.
The fogs do help a little.
I do get high beam flashes when I put the petal to the metal. My car tilts up and I see that line of light shoot up over all the cars in front of me. But I flash them back just to let them know what's up.
I love flashing people at me.. its like them saying "excuse me, but your brights are on" and you reply by further blinding them by saying "you wanna see bright? HERE'S MY BRIGHTS!".
Sigh.
Small note- drove to Detroit today to go shopping at Abercrombie. Saw a MSM TSX... you may not have heated mirrors... but that colour is awesome.
J.
Sigh.
J.
Sigh.
J.
Sigh.
J.
Sigh.
J.
Sigh.
J.
I don't get it... I know not to stare directly into any lights... but to say HID are not bright unless you are looking directly into them... well who's the bright one here? They are bright whatever way you look down the road. Not a big deal if you know how to drive but to dismiss this issue by saying not to stare at them is rediculous.
To me it's more a function of the projector lens... on the S2000 and I believe the TSX, the light is higly concentrated. I can't tell you how many people have pulled over to let me by because they are so god damn annoyed with my lights... hey, I can't get there faster without somebody in front of me... so I like them. Anyway, on my friend's MB S-class, his HID are just as bright but the lens difusses the light in a lot more places so you don't get the concentration of light that you get with the S2000 lens. Plus they self level which helps as well. Take notice the next time you are near an MB with HID and see how they did it. You will notice that you can look at the lights directly without too much of a problem... whereas you can't say the same with the S2000 len's.
Sigh.
J.
Sigh.
J.
