hid brightness problem
Old May 16, 2007 | 08:20 PM
shylo's Avatar
i just changed my hid headlights, but one is yellow and one is white. acura told me that they can adjust it so that i'll be the same brightness. has anyone ever heard of this? if so, please respond.... much help needed. thanks.
Old May 16, 2007 | 10:36 PM
ACURATECHTX's Avatar
I dont think you can adjust the brightness
where did you buy the bulbs
usually when a buld has a yellow light it is a faulty or old bulb
why did u change them in the first place?
did you change both or just one?
Old May 16, 2007 | 11:38 PM
clee109's Avatar
I Quit
A new HID vs. an old HID will have a different hue and "brightness" even if they are the same brand, that's just the nature of the bulbs. Each time you change bulbs you need to change BOTH to have the same hue or brightness. Also, if one is a slightly different kelvin rating that will relate to a change in hue and brightness. More kelvins = less usable/visible light on the road. The only way to check the Kelvin ratings would be to pop the bulb out and look at the base, each bulb will have it's kelvin rating written on the base.
If you have two different brands that will also cause a change. Phillips does not equal PIAA or Sylvania, or whoever else makes them (I don't think sylvania makes HID's but oh well, it's for illustration purposes). That being said, I have never heard of "adjusting brightness" you just need another new bulb from the same company and same kelvin rating.
Old May 17, 2007 | 12:48 AM
shylo's Avatar
i changed the bulb and ballast on my driver side only. i got the bulb and ballast at the acura dealership. the new bulb is yellow. you think its a bad bulb? should i return the bulb?
Old May 17, 2007 | 12:56 AM
shylo's Avatar
i changed the bulb and ballast on my driver side only. acura told me that the bulb and ballast had shorted out. when i turned on my old headlights, the light would turn on yellow and 5 seconds later turn pink and then go out after another 5 seconds.
i got the bulb and ballast at the acura dealership. the new bulb is the one that comes on yellow. you think its a bad bulb? should i return the bulb? i've been so frustrated with this light problem. i just bought the car pre-owned and i was having problems with both tail lights and head lights. (tails lights are fixed though)
Old May 17, 2007 | 07:13 AM
gftgrill's Avatar
it sounds like the new bulb hasn't burned it yet. the only thing I can think of to help is to either replace the other bulb. or you could turn the lights on and leave them on for a couple of hours to let the new one burn in.
Old May 17, 2007 | 09:54 AM
poltergeist's Avatar
Page 2 below answers your question.
http://www.in.honda.com/Rjanisis/pubs/SN/B070400.PDF
Old May 17, 2007 | 08:34 PM
shylo's Avatar
thanks a lot man. i was worried that it was gonna cause me more headache...
Old May 17, 2007 | 10:51 PM
bluesolara's Avatar
as a HID nut myself, I would have to disagree with the article
yes, the the new bulbs have to be BURNT-IN, but it doesn't mean after less than a day it will balance out to look like the other side
the Color of the bulb goes UP the COLOR TEMPERATURE chart after time of use, so a new bulb 4100k (white), will star to rise in color temperature due of normal wear, so a new bulb will NEVER match a used one.
change the other side too...unless you don't care about the color
Old May 18, 2007 | 12:46 AM
Tsx6363's Avatar
i think eh new bulbs need to be burnt in.. i was told this by my friends also... i haven't experienced it but yeah... they told me to leave my headlights on 24/7 (when driving) to burn it in quicker.. hope that helped
Old May 18, 2007 | 10:40 AM
SoCaliTrojan's Avatar
Let me help you!
http://faqlight.carpassion.info/hl-hid-bulbs.htm
This FAQ is from a forum used to be the Phillip's lighting forum I think...where all the hid nuts used to go.
Why does a replacement bulb look yellow?
Its very rare that a high quality (Osram, Philips, GE) HID bulb break, but if it does happen it would be a normal thing purchase same brand and model. It is a normal thing that a replacement bulb of same brand and model will look more yellow. Up until now, dealers have told custmers that there is not much to do about it, unless both bulbs are
To be in front of the marked, Philips introduced the "Plus" range of HID bulbs, to have a product that will not look yellow in a situation like this. See own section for the Philips 5000K bulbs.
As an aside...my accord's hid retrofit started out blue...and after a few hours of use, it's now really white....so maybe the lights are supposed to color shift towards the yellow part of the spectrum? I've never had to replace an OEM hid bulb, so I don't know how they are different...(by the way, the accord's retrofit bulbs are for a BMW)
Not to worry you though...if Acura mentioned it needs 14 hours to burn in, I'd try that first and see how well it helps.
Old May 27, 2007 | 01:35 AM
shylo's Avatar
i have a new problem, and it's not about the light being yellow. i changed everything correctly and the light stayed on for about a week. then all of a sudden, last night the light i just changed blew out and now it won't come on. if my original problem was a shorted ballast. could there be a possiblity that something is causing these shortage to my ballasts? (its only on the driver side hid headlight) for example: a fuse or a wire cross? can anyone show how the power is connected to my ballast then my bulb? much help needed. thanks
Old May 27, 2007 | 10:09 AM
gftgrill's Avatar
did you replace the washer between the ballast and the headlamp assembly?
Old May 27, 2007 | 09:14 PM
shylo's Avatar
if you're talking about the big black foam washer, then yes. if there's another washer than i don't know where that is located.
SidhuSaaB
May 30, 2020 12:40 AM
pistacio
Sep 26, 2015 09:45 AM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
Silverstead1
Sep 17, 2015 06:45 AM
