HELP!! VIOLENT vibrations above 45mph
Old Mar 29, 2007 | 08:06 AM
BigTime VTEX's Avatar
Hey All. My brother is about to buy a TSX. We went to go look at one. Everything was flawless about it, but when we took it onto the highway above like 50mph, there was a VIOLENT shaking of the steering wheel. The seller claimed he didn't know why the car shook so bad at high speed. I'm hoping its not anything major as he is pretty much locked into the deal already.
Any clues as to why I could be getting violent feedback at highway speed? P.S. The rotors looked pretty worn, but I'm not sure if that could that affect the steering? the tires looked ok, not sure if they were balanced properly...any similar experiences/fixed would be appreciated. Thanks guys.
Old Mar 29, 2007 | 08:09 AM
CGTSX2004's Avatar
Road force balance the wheels and tires. If the shaking continues, you may have a bent wheel. Even if the rotors are "warped" (which most likely is not the case), the shaking would only happen if you were braking, not just traveling in a straight line.
Oh, and thread moved to Problems & Fixes...
Old Mar 29, 2007 | 09:40 AM
visuelz's Avatar
East Coast Crew
For me even if there's a small problem with it, I will not buy it
Old Mar 29, 2007 | 09:44 AM
Ishakir's Avatar
Yes, back out of the deal now, while you still can...
This may be a fairly inexpensive problem, or something very expensive!
Old Mar 29, 2007 | 10:08 AM
rb1's Avatar
rb1
If it's a bent rim or out-of-round tire, it will be quite obvious when slowly rotating the wheel once the car is up on a lift.
I'd have a mechanic thoroughly check out the car, or otherwise you could just screaming for the door.
Old Mar 29, 2007 | 10:34 AM
acura_integra's Avatar
I had the same problem and it turned out to be the timing chain has skipped a tooth.
Old Mar 29, 2007 | 10:54 AM
dom's Avatar
dom
I've seen this be caused by having that tire patch stuff sprayed into a tire to seal a leak. If its not removed afterward, it causes vibration as the tire is unbalanced. Unlikely but possible.
Old Mar 29, 2007 | 01:01 PM
LuvMyTSX's Avatar
I agree with a Hunter Road Force balance. I had one done at my dealer after experiencing really bad shaking at highway speeds as well.
Old Mar 30, 2007 | 11:59 AM
tsxnation's Avatar
vibrations can be due to many things
-suspension problems
-wheels out of balance
-wraped rotors
Old Mar 30, 2007 | 01:43 PM
jerzpwr's Avatar
my guess is like those of others.... wheels might be not balanced.
Old Apr 4, 2007 | 08:56 AM
jspek.com tsx's Avatar
7th Gear
im sorry but that makes NO sense at all. if your timing was off it would show all over the rpm band. it would not only start to cause the engine to perfrom diff at 45+.
wheel shake is 95% of the time a out of balance rim/tire. its not a big deal.certainly not a reason to not buy a car.
Old Apr 4, 2007 | 10:08 AM
SimpleWhite's Avatar
you probably only need to get your wheels aligned, and maybe get the wheels balanced, you could have lost a wieght.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
