Help Troubleshooting HID Headlight -- Need your brain
Old Jan 8, 2011 | 04:14 PM
studville's Avatar
Doesn't Rice His Car
This all starts from here
https://acurazine.com/forums/1g-tsx-problems-fixes-128/headlight-i-screwed-mine-up-trying-change-bulb-need-little-help-801743/
But I seem to have fixed that problem. New problem
Summary: 06 TSX: When attempting to change a dimming HID bulb, I screwed up my control unit assembly. I bought a new one. I pulled off the bumper and both headlamps (in their entirety).
Through, troubleshooting I can identify it's not the ballast, bulb or control unit because when I swap the entire headlamp unit from the "bad" passenger side and plug them into the good driver side, it lights up. Same with if I swap the "good" driver side headlamp to the bad passenger side -- it doesn't work.
This leads me to believe that something has to be wrong PRIOR to where the harness clips into the HID headlight. Aggg this was not the case before. It worked fine before!!!!
Can someone help me out before I just drive my car into a wall and shell out the $500 deductible?
Old Jan 8, 2011 | 04:20 PM
studville's Avatar
So I got to thinking. Could it be a fuse. Does each headlight independently have its own fuse?
Old Jan 8, 2011 | 05:06 PM
studville's Avatar
Disregard. I fixed it!! It was a fuse. Thank god! Will post summary when I finish up
Old Jan 8, 2011 | 06:27 PM
studville's Avatar
My headlight is all fixed with bumper back in place. I'd like to thank Pacman for the help while I figured it out.
As a learning lesson. The black connector that is on your HID controller DOES NOT come off (even though there are screws holding it in).
Old Jan 8, 2011 | 10:16 PM
PACman's Avatar
Glad to be of service.
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
Mr.Tea
Oct 2, 2015 10:32 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
