Help with a few questions.
Old Apr 3, 2012 | 05:12 PM
04redone's Avatar
3rd Gear
Hey guys i have a few questions. i ave an 04 TSX i got recently. I searched for this but want some clearification. thanks in advance.
Problom 1: No lights on clock, radio, or hvac. I know this is common and fixable. What is the odual called that goes bad. and is it covered by acura, if so how long?
Problom two: when i hit small bumps in the road such as going down the highway the car "Bump steers". I was told it is because it is front wheel drive however somebody hit the car when it was parked one night i got it fixed and therer was no frae damage but when i got it back it never drove the same. the bump steer got worse.
Hopefully you guys can help me out as i like the car just a few probloms with it.
THanks in advance.
Old Apr 3, 2012 | 06:28 PM
04redone's Avatar
3rd Gear
Also just remembered this. No fuses are blow. But the tail lights only the right side works if the lights are off. when the headlights are on both brake lights work.
Old Apr 5, 2012 | 11:31 AM
04redone's Avatar
3rd Gear
No body can help me out here guys?
Old Apr 5, 2012 | 12:07 PM
PACman's Avatar
This may or may not help you, but anyways...
There's a TSB for this. http://photos.imageevent.com/astrobo...sb/B04-021.pdf
How are the wheel alignments?
Old Apr 6, 2012 | 12:08 PM
Mr. DB2's Avatar
The illumination issue is the audio/HVAC control panel is bad. Very common. I have had to replace it on my current TSX. I recommend you look on ebay or car-part.com.
Your second issue,I recommend you have your alignment checked and check your tire inflation.
Your tailight issue is most likely a grounding issue. Check all your grounds and control modules.
mike in bmore
Jan 4, 2019 07:16 PM
emailnatec
29
Sep 28, 2018 04:27 PM
BoricuaTL
Apr 8, 2016 01:08 PM
Type S Zero
Feb 17, 2016 02:37 PM
VolkingTL
Sep 16, 2015 09:10 PM
