Help with a few questions.
Hey guys i have a few questions. i ave an 04 TSX i got recently. I searched for this but want some clearification. thanks in advance.
Problom 1: No lights on clock, radio, or hvac. I know this is common and fixable. What is the odual called that goes bad. and is it covered by acura, if so how long?
Problom two: when i hit small bumps in the road such as going down the highway the car "Bump steers". I was told it is because it is front wheel drive however somebody hit the car when it was parked one night i got it fixed and therer was no frae damage but when i got it back it never drove the same. the bump steer got worse.
Hopefully you guys can help me out as i like the car just a few probloms with it.
THanks in advance.
THanks in advance.
There's a TSB for this. http://photos.imageevent.com/astrobo...sb/B04-021.pdf
The illumination issue is the audio/HVAC control panel is bad. Very common. I have had to replace it on my current TSX. I recommend you look on ebay or car-part.com.
Your second issue,I recommend you have your alignment checked and check your tire inflation.
Your tailight issue is most likely a grounding issue. Check all your grounds and control modules.
emailnatec
29
Sep 28, 2018 04:27 PM
BoricuaTL
Apr 8, 2016 01:08 PM
