Help with '06 TSX
Old May 25, 2016 | 08:15 AM
smalls06's Avatar
Help with '06 TSX
Good Morning All
I have a 2006 Acura TSX 6spd with 140k miles and I am having some issues...when in neutral (stopped) the car RPMs will rev up and down from 1000 to 3000ish and the check engine light and VSA lights are on. Then after stopping and having the car off for a few minutes the check engine light is the only one and the RPM rev went away. This has happened before but only when the car would be around 15% oil indicator. After an oil change the problems went away. The car is currently at 80% oil.
I took it to Advanced to have them do the diagnostic test and these are the codes I am getting: 61-1, 83-1, P1009.
Any tips and help would be greatly appreciated!!
Old May 25, 2016 | 02:41 PM
Jdrum1's Avatar
Iirc, P1009 relates to the vtec solenoid.
Vtec actuation is based on oil pressure, so have you checked your oil level?
There's also a screen on the solenoid that can sometimes get clogged.
04SSMnMD
Jan 5, 2017 08:16 PM
beaglepower
Aug 15, 2016 07:27 PM
hondas2kcr
Mar 11, 2016 08:22 AM
lukej303
Mar 2, 2016 02:40 PM
