Handsfreelink - lock code
Old May 9, 2007 | 11:02 PM
T-Squared's Avatar
Dear All,
Purchased a used 2006 Milano Red TSX, no NAV. Trying to setup the HFL with my Treo 700wx. The system tells me it is locked and needs a 4-digit code. Attempts to clear the system as directed by the manual have failed.
Any idea how to reset the system?
Old May 9, 2007 | 11:57 PM
gt0279a's Avatar
From what I understand, only the dealer can unlock it.
Old May 10, 2007 | 01:24 AM
Ride Slow Homey's Avatar
AlwysCleanURArely c ASpec
Try the password of 0-0-0-0
Old May 10, 2007 | 01:25 AM
mltk53's Avatar
I can't find my garage
or maybe u can try to radio code? lol i dunno
Old May 10, 2007 | 02:09 AM
kjamsf's Avatar
Berserker (+9)
Try your ATM pin...and keep us posted
Old May 11, 2007 | 05:58 PM
T-Squared's Avatar
I thought sure the ATM pin would do the trick...alas, no love. :o)
Any other thoughts?
Old May 14, 2007 | 01:48 PM
lkeller's Avatar
3rd Gear
same problem you have
I just bought a 06 TSX and it has the same problem that you have. I called HandsFreeLink and they told me that it must be rebooted by Acura. I'll let you know if I come up with anything.
Old May 14, 2007 | 08:05 PM
zooter's Avatar
Owner - Operator
Lock Code
Sounds pretty obvious, but did you check the manual? When I bought my TSX the dealer had a sticker or card with the Nav and radio codes and poped it in the owners manual.
Old May 14, 2007 | 10:44 PM
evantec's Avatar
Ev an' Tec
Originally Posted by T-Squared
Dear All,
The above sounds like a Bluetooth handshaking/pairing issue, not anything about security for a NAV system (which you don't have) or the radio.
When Bluetooth items are paired, one of them asks for (or sends out) a code, which the other must supply. For things like headsets (which don't have a keypad to enter a code), the code might be hard-coded to 0000. For something like a Treo, you might be prompted to enter a code into the Treo, and then speak it into the HFL (or vice-versa).
You might need to look at the Treo manual and see about setting Bluetooth so the device (treo) can be "discovered" for at least a few minutes while you do the pairing process. If possible you also don't want to do this in a public setting where other people and Bluetooth devices are in use -- i.e. at a train station, mall etc. Find an empty parking lot away from things, or go in a garage..
Also, if the Treo is currently paired to a headset, it might not be able to connect to the HFL at the same time. So you want to do this whole process when the other devices are off. (Bluetooth can go 30 ft and sometimes 300ft. If your headset were in your house, the Treo might still connect to it from the garage, so the headset really needs to be off when you pair the Treo to the HFL.)
Good luck. Check the other Treo threads if you still have questions (incl other forums - TL / RDX / MDX etc).
Old May 14, 2007 | 11:33 PM
Tsx6363's Avatar
Read The Manual!!! 0-0-0-0
Old May 18, 2007 | 09:11 AM
lkeller's Avatar
3rd Gear
lock code
I have tried every 4 digit code in the book including 0-0-0-0 and I still can't get pass the lock code. Infact, I can't find this particular mode even in the manual. I guess the next stop will have to be the dealer.
Old May 18, 2007 | 11:48 PM
T-Squared's Avatar
Tried lots of codes - no love
I've tried several codes to no avail. I've turned off my Treo and the ear piece and still no love. The prompt for the lock code is immediate. As soon as I press the talk button, a female voice comes on saying, "THe system is locked, please enter the four digit pass code".
Old May 19, 2007 | 02:10 AM
subdued's Avatar
my acura sanctuary
Having just set up my bluetooth phone 2 days ago, I know that there is an option during HFL SETUP to use custom PIN to lock out unauthorized use (note: this is not the user selected 4-digit code used during the car/phone pairing process) So, it seems like both posters above have purchased cars where the previous owner chose to use the security PIN. Dealer RESET seems like the only next step.
Old May 19, 2007 | 02:12 AM
subdued's Avatar
my acura sanctuary
If the user chose to create a custom PIN then 0000 would not work.
Old May 23, 2007 | 10:58 AM
White92's Avatar
Did you buy it used from a dealer or private party? If it was private party, I would contact them and ask them what their code is. If it was an Acura dealer, then I would explain to them that they sold you a car that had the HFL locked by the previous owner and they need to reset it. I would push for free since they sold it to you like that.
The previous poster is right. This isn't the 4 digit code used for pairing the phones. This is an optional code that users can use to block unwanted use.
Old May 25, 2007 | 11:06 PM
Stevestr's Avatar
Looking at the '15 TLX
Evan is right. Have you done *all* of these steps as suggested by Acura?: (they come directly from the Handsfree site at Acura)
PalmOne Treo 700w Verizon Pairing Instructions: Print | Back
  • IMPORTANT: You must press and release the HandsFreeLink talk button on the steering wheel and wait for the beep before you speak. This step is required before all spoken commands.
  • Power on the phone and ensure Bluetooth® is ON. Please refer to your phone's user guide for steps to turn on Bluetooth.
  • Press and release the Talk button on the steering wheel and wait for the "beep" before you speak.+Repeat this step before all spoken commands.
  • Say "phone setup"
  • Say "pair"
  • Say any 4 digit PIN code for pairing. Remember it as you will need to enter it into your phone later. HandsFreeLink will now instruct you to begin the pairing process in the phone.
  • On the Treo, Tap START
  • Select SETTINGS
  • Select CONNECTIONS
  • Select BLUETOOTH
  • Make sure BLUETOOTH ON
  • Make sure Dial-up Networking is OFF
  • Tap the DEVICES TAB
  • Select NEW PARTNERSHIP
  • Wait for Handsfreelink to appear
  • Treo will now search
  • Choose "HandsFreeLink TM"
  • Tap NEXT
  • Enter 4 digit PIN Code
  • Tap NEXT
Old May 30, 2007 | 08:09 PM
T-Squared's Avatar
Not a Pairing Issue
Thanks for all of the replies. I purchased the vehicle through an eBay power seller who just happened to be local. I have a call into him. With the number of cars that go through his shop, it is doubtful that he will have the code.
This issue is completely separate from the Treo...again, not a pairing issue.
I plan to take the car to an Acura dealer once I get a few more miles on her. I just had a subwoofer installed. I thought that when the disconnected the power to set everything up that might do the trick.
Unfortunately it got me no further than my ATM pin.
Old Jun 5, 2007 | 05:52 PM
YVRTSX's Avatar
I don't know if this procedure is different from what is in the manual, but check out the May 2007 Service bulletin - there's an item in it regarding clearing the code.
https://acurazine.com/forums/showthread.php?t=34037
Old Jul 9, 2007 | 09:23 PM
T-Squared's Avatar
Issue Resolved
The technician at Acura used the (5) steps in the May bulletin and I can now get into the system.
I will go through the pairing process this evening. The Treo 700wx has a THB kit icon that is specific to car auto answer features. I need to read about this feature in the manual to see exactly what it does.
Again, thanks for pointing me to the tech bulletin.
Old Jul 9, 2007 | 09:46 PM
Nmbur10's Avatar
7th Gear
mine was 1-2-3-4 ...if anyone else can use that information.
Old Jul 10, 2007 | 09:53 AM
lkeller's Avatar
3rd Gear
cost to reset password
How much did they charge you to reset the password using the 5 steps? Did you have to leave the car or did they do it while you wait?
Old Jul 11, 2007 | 02:29 PM
fodzy147's Avatar
sounds like the previous owner had a passcode to get into his hfl. you can set a password to use the hfl before you can make a call.
Old Jul 11, 2007 | 04:29 PM
T-Squared's Avatar
They did not charge me. I set the expectations in my e-mail request for service.
I had the 15K mile svc done and a couple of other things so I left it there.
Old Aug 5, 2010 | 02:14 PM
7dOPP's Avatar
I have the same situation, however, the Acura dealership wants to charge me $135 to clear the system. Can I do the 5 steps myself?
Ron
Old Aug 5, 2010 | 03:18 PM
Simba91102's Avatar
Old Guy
Ron
This thread is over 3 years old, so those that contributed may not still be on the site. I'd advise you contact a dealer.
Old Oct 19, 2010 | 05:59 PM
rhannahs19's Avatar
grr i am having this problem with a 2008 tsx, sorry to bring up a dead thread, but any updates?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
