Handsfree Issue
Old Mar 19, 2011 | 11:33 AM
stretchandpoke's Avatar
4th Gear
Handsfree Issue
Hey guys,
I bought the TSX used equipped with GPS from a dealership. Unfortunately, the previous owner did not clear the handsfree/bluetooth passcode before selling the car.
I read on the manual on how to reset the passcode but unfortunately I think it only works if I actually knew the current passcode.
Is there anyway I can reset the passcode without actually getting into the system (as without the current passcode, the system seems to be locked).
Thank you so much for your help.
Old Mar 19, 2011 | 04:14 PM
RA032025's Avatar
in the 24th and a half...
HDS is required to reset the passcode. If it was a Honda/Acura dealer, you should be able to get them to do it for free. You can try 888-528-7876, Acura Client Relations for HFL.
Old Mar 20, 2011 | 06:59 PM
asmcbride's Avatar
same issue here..
friend just bought a used '08 TSX w/ navi yesterday from the closest dealer which is over 2 hrs away...today we tried to setup the bluetooth to pair to her iPhone and can't get anywhere with it...the HFL keeps asking for a 4-digit code and the system doesnt even seem to recognize the "Phone Setup" command at all...not sure what we're going to do...need some help
Old Mar 21, 2011 | 04:48 AM
SoCaliTrojan's Avatar
Let me help you!
"Phone Setup" will only work from the main menu (not inside phone book, etc). Cancel out of HFL and make sure it's the first command you use. Then use the "pair" command. It will ask you for a 4-digit passcode...say any number you want. When it starts looking for your phone, make sure it is discoverable, and then type in the same 4-digit pass code. It should then continue on and ask you what you want to name that phone (since you can have multiple phones paired with the system).
As for the OP's question, I can't imagine the HFL system insisting on a pass code. I would just go in there, delete/unpair all of the cell phones, and then try from scratch. The pass code is a number used in the meantime during the pairing process so that the system can identify which phone to pair with (in case there are several nearby phones).
Old Mar 21, 2011 | 08:44 PM
asmcbride's Avatar
the tsx absolutely will not recognize the 'phone setup' command...what gives? not having any luck getting this bluetooth setup/phone paired...
snorf
Nov 4, 2019 06:44 AM
visiter555
Apr 9, 2016 12:56 PM
Frathora
Sep 28, 2015 11:29 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
carz0159
Sep 20, 2015 06:11 PM
