Guide to replace 5AT Tranny fluid?
I spent about an hour searching posts on how to replace the tranny fluid on a 5AT. most threads discussed in the past have member discussing when to change fluids/what types of fluids to use. After reading the owners manual and researching from other sources, I can't find where the drain plug for the tranny fluid is, and is "flushing" the tranny three times adequate enough? Or better yet, has anyone posted a complete guide to replace the tranny fluid, maybe even with pictures?
On a side note, can someone tell me where is the location of the engine oil filter? I jacked the car up and when underneath for about 15 minutes. I changed the oil but I have no idea where the oil filter is. Thanks!
Look at post #20 in this thread: https://acurazine.com/forums/showthr...t=transmission
That gives you the drain plug location. Flushing (i.e. drain then fill) 3 times should be adequate. It will replace 81% of the fluid.
Reposting from another thread
Originally Posted by jlukja
1st drain/fill = 43%new fluid (3qt new, 4qt old)
2nd drain/fill = 67%new fluid (3qt new, 4qt*43%)
3rd drain/fill = 81%new fluid (3qt new, 4qt*67%)
Originally Posted by loulinjai
anyone can help me out?
For the oil filter, you will have to get under where the down pipe from the header comes out (this means getting further under your car) and look towards the passenger side, you should see the filter. Good luck.
mada51589
05-03-2022 08:54 PM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
HeloDown
09-08-2015 06:51 PM
