Gps And Radio Signal Problem!!
Old Sep 9, 2005 | 12:31 AM
mohfoe22's Avatar
Angry Gps And Radio Signal Problem!!
i have a 2004 tsx. i believe all the antenna stuff is on the back window. i bought the car used, and it has tint. after researching about the metallic tint problem; i just recently removed the tint and i still have the same problem. when i drive on the highway, everything is fine the gps recognizes which highway i am on. however, the radio signal is still somewhat weak. when i drive in residential areas, the gps does not recognize what road i am on. does anyone have this problem? please help.
Old Sep 9, 2005 | 12:46 AM
Alin10123's Avatar
Underneath the LCD screen push and hold down the first 3 buttons on the left at the same time that control the Navigation.
I believe the buttons are mapguide, cancel, and menu.
Then on your screen touch "gps information".
You should see how many satellites your nav system is picking up. If it's less than 3 at anytime, your gps wont be accurate. The more satellites at one time the more accurate it is.
Is your TSX still under warranty? Take it into the dealer and have them take a stab at it if you can't pickup at least 3 satellites.
Old Sep 9, 2005 | 12:57 AM
mohfoe22's Avatar
yes i have gone to the diagnostic screen, and i do come up with more than 3. about 5 - 6 range constantly, but still my radio signal is weak and residential streets do not display on the bottom of the screen.
Old Sep 9, 2005 | 08:07 AM
GIBSON6594's Avatar
My Garage
hmm, try letting the nav reset itself. Disconnect the battery for 30 seconds. make sure you have your password before you do it.
Old Sep 10, 2005 | 03:14 PM
mohfoe22's Avatar
Resetting Navi Worked!
thanks for the suggestion about disconnecting the battery. that seemed to solve the problem my navi and radio is working at full strength! thank you so much.
rockyboy
Aug 4, 2024 10:35 AM
Ty-Sama
Sep 21, 2015 05:45 AM
Greengecko
Sep 16, 2015 08:19 PM
vanderveen44
ILX
Sep 16, 2015 10:51 AM
andysinnh
Sep 5, 2015 11:38 PM
