fog lights don't work
Old Aug 18, 2006 | 01:32 PM
Michel Weber's Avatar
I decided to see what the fog lights look like, I turn the switch on the turn signal switch and nothing. I haven't checked the fuse yet. Has this happened to anyone? Just got the car last week and no, I didn't check it before leaving the dealer's lot.
Old Aug 18, 2006 | 02:12 PM
Dan Martin's Avatar
Photography Nerd
I think you need to have your headlights on at the same time for them to work, but I don't have fogs so I'll need someone else to confirm that.
Old Aug 18, 2006 | 02:36 PM
RMATIC09's Avatar
Old Aug 18, 2006 | 04:42 PM
ckiggins's Avatar
That is correct, low beams must be on for them to work.
Got freaked out when I left the fog switch on one day, but turns out as long as the headlights are off there's no battery drain.
Old Aug 18, 2006 | 04:43 PM
Ok - I never thought to try that. But it seems to me that they should go on without the head lights - I'll report back later. Thanks.
Old Aug 18, 2006 | 06:32 PM
ILoveMyHonda's Avatar
17781708
Unless u have aftermarket fogs......they only turn on with the low beams.
Old Aug 19, 2006 | 09:47 AM
Sure enough, the headlights need to be one before the fog lights will turn on. The manual says it as well. Kind of defeats the purpose doesn't it.
Old Aug 19, 2006 | 10:26 AM
poltergeist's Avatar
As I understand it, it's a DOT requirement.
Old Aug 19, 2006 | 02:58 PM
feelgood13's Avatar
come on now... did you really think that the TSX fog lights were for driving in foggy conditions? do you think the rear spoiler is to provide downforce on your back wheels? its all for style points!
Old Aug 22, 2006 | 07:13 PM
CometVR4's Avatar
I doubt it. Its manily just Japanese cars thats like that.
BMW, Mercedes, GM cars, Fords and some others you can turn the fog lights on without the low beams but you have to have the parking lights on.
Old Aug 23, 2006 | 04:00 PM
stixbc's Avatar
Speaking of fog lights - this might sound stupid - but what's the rule of thumb for turning them on? ie - only in the fog? Or can I turn them on anytime? I was driving down to SoCal last weekend and I saw quite a few cars with both their low beams and fogs on. I simply don't know the legality of it all. Thanks!
Old Aug 23, 2006 | 04:09 PM
mrgold35's Avatar
mrgold35
As long as the fog/driving lights are aimed correctly, not blinding other drivers and keep the wattage between 35-55 watts, you should be AOK. Just don't change out to a 100 watt PIAA off road bulb and night blind on comming traffic.
Old Aug 24, 2006 | 07:47 AM
As for the fog lights... yes. But not the spoiler - I already knew that its a total cosmetic thing. I often look and them on other cars and think "that thing has so little support in the center, how can the driver think its actually doing something"... but then I need to remind myself its all for show.
Old Aug 25, 2006 | 10:23 PM
CometVR4's Avatar
100w bulbs can also melt your wiring harnesses
theinsvnity
Sep 10, 2015 10:22 PM
drewdeezy03
Sep 3, 2015 08:04 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
