First gear????
Old May 9, 2005 | 05:35 PM
Stokeless_TSX's Avatar
Stokeless
First gear????
I don't know what it is but sometimes when I gun it hard all way up to red line or close to it...my car doesnt want to come out of first gear..and I am out of warrenty =( What do you think it is?
Old May 9, 2005 | 05:44 PM
leftride's Avatar
i want to ride my bicycle
you mean you push in the clutch and cant pull the shifter back?
Old May 9, 2005 | 06:01 PM
Stokeless
Yea I can get it out but I gotta pull alot harder than normal..WTF...?????
Old May 9, 2005 | 06:10 PM
leftride's Avatar
i have had problems going into first, but never leaving....you got me, looks like a trip to the damn dealer is in order
Old May 9, 2005 | 06:47 PM
joerockt's Avatar
Just dial 1911
Symptom of a burned out clutch
Old May 9, 2005 | 06:55 PM
GIBSON6594's Avatar
My Garage
Sometimes a low amount or bad clutch fluid will make shifting more difficult.
If thats all it is, thats nothing to fix
Old May 10, 2005 | 12:41 AM
Stokeless
thanks i'll check it out =)
Old May 10, 2005 | 12:45 AM
Canyonball's Avatar
Apex Clipper
I don't think it's the clutch, sounds like a synchro problem in your tranny... Good luck on the fix!
Old May 10, 2005 | 10:55 AM
Stokeless
I hope not!! That would suck..If it was that though I would get a Type S tranny and lose my VSA =)
Old May 10, 2005 | 11:11 AM
Canyonball's Avatar
Apex Clipper
I think the labor would be the killer to replace a synchro, other than that you might even want to upgrade to carbon instead of the brass unit.
Is a Type S tranny a possible swap? I never heard that one before...
Old May 10, 2005 | 11:30 AM
fdl's Avatar
fdl
I you sure you are out of warranty. Isnt the drivetrain warrantee 5 years 100,000?
Old May 20, 2005 | 05:20 PM
calijeff's Avatar
4 Year 50,000 miles
Old May 20, 2005 | 07:20 PM
madmanmax3000's Avatar
Professional Newbie
major transmission work? sounds like somebody's getting a lightweight flywheel
Old May 20, 2005 | 08:09 PM
TechSX's Avatar
Tech
Sounds to me that the clutch is still grabbing while you're shifting. Basically feels the same as if you were to do clutchless shifting. It'll have a more restrictive feeling when going in and out of a gear. It could be that you're shifting so fast, that you're not letting the clutch disc fully disengage itself from the pressure plate. You might not notice it, but you might be pulling at the shifter before your clutch pedel drops. Im not questioning your driving skills or anything, just stating some possibilities. Hope this helps
Old May 20, 2005 | 08:17 PM
TechSX's Avatar
Tech
Definitely not synchros. Synchros are used mostly when going into a gear, but Stokeless is complaining its hard coming out of a gear. Signs of a bad synchro usually means grinding.
Old May 20, 2005 | 09:17 PM
PixelHarmony's Avatar
Master Graphic Artist
I sometimes have problems going into reverse, someone said it's because there are no syncros so I'd assume if that logic is correct then TechSX is correct.
If you are out of warranty will the dealer still look at it for free and give you a diagnostic?
Old May 21, 2005 | 06:54 PM
Professional Newbie
the reverse gear/ first gear can sometimes be hard to engage, just movie it all the way to each side in neutral and try again, that usually works for me
Old May 21, 2005 | 07:20 PM
Alin10123's Avatar
Probably not.
I mean if you go into for an oil change and they take a quick glance, then probably not. But if you want them to find a problem then it'll probably be their hourly rate until they find something.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
joflewbyu2
Oct 8, 2015 11:16 AM
AcuraKidd
Sep 26, 2015 04:10 PM
